uMMC to Prop?
Hello all,
I am working with a uMMC Rogue Robotics SD card reader/writer. I am hoping to be able to sync up the uMMC to the prop so that I can pull programs from the uMMC to the prop board. Ultimately, I'd like to be able to have a virtually unlimited memory space (dependent on the SD card size) for the prop using the uMMC. However, I am unsure about how to begin such a task.
Hopefully that makes sense... Any ideas?
Lucy
Lucy
http://obex.parallax.com/objects/39/
If it works well for you let me know. I have lots of MMC cards I'd like to use that seem to be incompatible with my SD's.
Aka: CosmicBob
Speaking of, if anyone has used this object before and has any tips to share, that'd be much appreciated, although these programs look fairly self-explanatory.
Thanks!
