Help with BASIC Stamp II and Servos
I'm trying to simply power a couple servos with a 4 AA battery pack. When I plug the servo directly in to the battery pack it will only spin one direction. When I connect the battery pack to the BASIC Stamp II carrier board directly and wire it through Vin and Vss I can get it to change directions and work properly but I didn't want to do this because I read you could hurt the motors. Does anybody know why this is not working properly? Also one of the servos I have won't move at all anymore no matter how I connect it. I think it has something to do with using the servo controller board with it but I'm not sure. Any suggestions?
If it works using the carrier board, but not using a direct power connection, then there must be something else you're doing wrong and I can't tell from your limited description. I suggest you make a schematic diagram of your two setups and post that as an attachment to your next message. Make sure the diagrams reflect your actual connections, not what you think you have ... often the two are different.
2) The servos are the largest power drain. Under heavy load, they can draw as much as 1A each. Average current when running lightly loaded is on the order of 1/4A and the idle current is even lower.
3) Regarding wiring ... use common sense. Look at the cable coming from the servo. It's probably 6-8" long. You could easily double or triple that length using the same size wire and do just fine. Longer extensions and you'd want to use heavier gauge for the power leads and you'd want to do something to reduce noise on the control signal lead.
