Using the Propeller to measuring Liquid Conductivity from the Applied Sensors T
I was reading the parallax guide to Applied Sensors for the basic stamp. http://www.parallax.com/dl/docs/books/edu/AppliedSensors1_3.pdf I want to recreate the electrical conductivity lab described in chapter 5 on the Prop instead of the basic stamp2. Can I use the schematics on page 121 and 128, unchanged on the prop? Just the parts in the schematics involving the conductivity sensor and the LM555 timer. I know the prop is 3.3v and the BS2 is 5v.. So I suppose not. Can anybody shed some light on this?
the DS1620 and the NE555 work as a special kind of analog-to-digital-converter (ADC)
The connection to the BS2 or the prop is a digital interface. A digital interface has two states:
1.) HIGH (+X Volt) and
2.) LOW (0 V)
You can connect most digital interfaces which use 5V to the propeller as it is described in the sticky thread
HOW TO SAFELY INTERFACE A 5V SIGNAL TO THE PROPELLER?
http://forums.parallax.com/showthread.php?p=585920
The circuit with the DS1620 or NE555 will still be supplied with 5V.
ATTENTION ! don't connect 5V directly to the prop-IO-PINs ! USE the circuits described in the tread above
The circuits might work at 3.3V too if the datasheet of the DS1620/NE555 has a supplyvoltagerange below 3.3V
The frequencies will change. But it should still work.
As 3.3V is a lower voltage than 5V there is no danger to expermintate with 3.3V
best regards
Stefan
Tracy Allen
www.emesystems.com
