Power Supply Design for Propeller
I am toying around with a few ideas and applications for the Propeller.· One of the ideas is a generic button/LCD interface.· I have a thread in the sandbox forum where I am exploring and designing the concept further.
http://forums.parallax.com/showthread.php?p=736828
For this idea, and my other ideas, I want to explorer the power regulation circuitry more.· My past designs used the LM1086s just like the Propeller·Protoboard.· This works well, but not under the constraints I would like for the new design.· I would like a power system that
I am thinking the design will have to be some sort of DC/DC switching regulator in a buck mode format.· What thoughts or suggestions do you have?· Anyone done something similar already?
Timothy D. Swieter, E.I.
www.brilldea.com·- Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto fo SunSPOT, BitScope
www.sxmicro.com - a blog·exploring the SX micro
www.tdswieter.com
- Can accept 6 to 12V DC input - maybe up to 24V DC
- Doesn't require a heat sink
- Minimal components (isn't this always a constraint?)
- The component packages should be SMT, but hand solderable
- 3.3V DC and 5V DC output
www.tdswieter.com
http://www.recom-international.com/switching_regulator_R-78xx.html
Not cheap, but when you realize you don't need any heatsink, the low profile
and small board space, just a perfect component. They even have a 1A smd version.
Two links to datasheets are at the bottom of the page.
regards peter
http://www.national.com/pf/LM/LM2675.html
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
www.tdswieter.com
I have been using the Simple Switcher series for 7 years. The physical board layout is important, as is choice of inductor.
The sample printed circuit board assembled by National engineers to provide a complete reference design is in my hand.
The complete board is 1 inch by 1/2 inch. It provides 1 amp at 5v.
I can mail it to you if you PM me to provide mailing details for your complete address.
Is it all right to re-use the mailer that you sent me?
JMH
Post Edited (James Michael Huselton) : 3/19/2009 7:34:37 AM GMT
Thanks for the offer James, at the moment hold on to it. I am interested in seeing it, maybe you can post pictures? I am saying don't send it because I am doing lots of traveling in the next couple weeks and I may also be relocating to Singapore. So, anything sent in the mail at this point I may not get depending on schedule.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Post Edited (Timothy D. Swieter) : 3/19/2009 8:41:48 AM GMT
Futurlec (Thailand) have a range of what they call Mini- Boards.
Among the range are some ready built , LM2575 based, regulator boards.
You can see them here
www.futurlec.com/Mini_Power.shtml
Prices are $US, and seem to be quite reasonable.
kenmac
Perth, Western Australia
Time Zone = GMT + 8
The only real difference between the two switching chips is that the 2675 runs at 1A and a higher frequency so that it needs a smaller inductor (although the 100uH works for higher voltages). I allow for the extra little bootstrap cap that the 2675 requires whereas that pin is a 'not-connected' on the 2594 so it doesn't hurt.
I keep a few of these in my little protoyping parts box as they come in handy at times.
*Peter*
· Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
Need to make your prop design easier or secure? Get a PropMod has crystal, eeprom, and programing header in a 40 pin dip 0.7" pitch module with uSD reader, and RTC options.
*Peter*
Using these simple switchers in a design are pretty easy.
www.tdswieter.com
