Simplest code not working
I am trying to connect to the mini SSC II, I have this and for some reason it isnt working
Hunger hurts, starvation works!
CON
_clkmode = xtal1 + pll16x '80MHz operating frequency.
_xinfreq = 5_000_000
VAR
byte position
OBJ
comm : "Simple_Serial"
PUB main
comm.init(0,-1,9600)
repeat position from 0 to 254 step 1
send2SSC(255, 0, position)
waitcnt(1_000 + cnt)
PRI send2SSC(sync, servo, pos)
comm.tx(sync)
comm.tx(servo)
comm.tx(pos)
'Still some PropSTICK Kit bare PCBs left!
comm.init(-1,0,-9600)
The SSC manual says the data should be inverted
You are trying to send characters in the serial but you need to send this information as
· comm.dec(...)
I presume the simple_serial has the same options as FullDuplexSerial object. There is also
· comm.hex(...,8) 'where 8 is the number of hex digits you want to display
It is possible that the spin code is slower that the 1000 you have added to cnt - try 1_000_000 just to be sure.
