12 Vdc water pump controler-advice needed
Hi there,
I am looking to use my stamp if possible to control a water pump.
What i need is to be able to adjust its on/off sequence from just under a second up to 10 seconds or there abouts - this is easy enough i think to sort out but the problem is i need to have it running full at 12v when on and down to 4ish volts when "off"
Any pointers please as i am sure you clever guys and galls can figure this out!
List of parts would be helpful also! i have the stamp and a collections of bits, power packs, solid state relays!
All i need is a clue
it good when someone puts a bit of common sense into the equation!
I am looking to control a powerhead and was concerned that just switching on and off would damage the pump!
the idea is for a wave maker for my fishtank and was thinking of a digital potentiometer to control a transistor with 12v running through the C and E.
The thinking was to have the pump on full tilt (12v) for a second and reducing in speed to about the 4v to keep the propeller ticking over for a second............to get a backwards and forwards swell going!
It never occurred to me though that the pump wouldnt work with less than 12 volts!
cheers,
levi
