I need a calculation for what the voltage drop is on # 10 wire (Resolved)
Hi Every One
On to something new
Let me·first·say Thanks to all that have help me in past on the forum
I starting a new project and·I need some input
This ·
·came from a kit project from many year a ago· for a
Five Amp·Electronic Fuse
and their project they had four·resistors in·parallel and a transformer on the
AC side of the board then that input when to LM339 if i remember right
One·
·I know that AC voltage can KILL YOU if you are not care full·
·I WILL BE VERY·CARE FULL
I want to do this the·POOR MAN·way I want to use what I have on hand
This calculation may be off but i looking at some thing like this
I am going to use a transformer that is 12 volt to 110 volt amplifies the
· 500 mil to 5·volt so·I can use ADC chip
I want to get about·2.5 mil volts per amp of current off of the transformer
when done
What·I need to know what is the voltage drop on # 10··solid wire·per foot
How many·feet do you need to get·a·500 mi volt drop @·20 amps
And like I said earlier I will be safe about what I am doing
··Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 7/25/2008 8:13:31 PM GMT
On to something new
This ·
![idea.gif](http://forums.parallax.com/images/smilies/idea.gif)
One·
when done
··Thanks for any·
Sam
http://www.cirris.com/testing/resistance/wire.html
Thanks for the web Link
I used the AC voltage drop calculator at there web page and it was a lot of help
PJ
Thanks for the web link
·I also used their calculator as well This also was a lot of··help
Now I have the tool to get this project off the ground
·The ·calculator said
For # 12 wire would be·6.5 feet
This would give a voltage drop of······520 mil volts @ 20amps good enough
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/25/2008 8:20:29 PM GMT
· A 12V to 110V transformer will only raise 50mVac to 500mVac or 0.5Vac not 5.0Vac.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
A 12 V to 110 V transformer will only raise 50 mil V ac to 500 mil V ac or 0.5 V ac not 5.0 V ac.
I move the decimal point to many places thanks for catching this mistake
Thanks for the info
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/25/2008 8:19:32 PM GMT
