Why a 10MHz crystal?
Just picked up a hydra (mostly for the book!). Why is the crystal 10MHz? Is it better to run a faster crystal & lower PLL multiplier?
Concentrate on understanding the problem, not applying the tool
Andre'
My experience — at least with broadcast video — has been different. I get a much cleaner broadcast signal (Channel 3 - 60 MHz) at 5 MHz and pll16x than I could at 10 MHz and pll8x. In the latter case, there was quite a bit of hue drift through a given scan line that did not present at the lower crystal frequency, even though this was not apparent in baseband video. There may be factors in my setup that have thus far eluded analysis; but, so far, the crystal frequency appears to be the only variable. My initial conclusion was that the PLL syncs to a 5 MHz input more reliably and with less jitter than it can when being driven at 10 MHz.
'Still some PropSTICK Kit bare PCBs left!
I think the take way is for anything analog, you have to test things, and cover the application area you are using and see what works best.
Andre'
