Stamp2SX Controling HD Projector
Hello all!
I am trying to control on/off and input source on a Panasonic Projector via rs232.
tp.panasonic.com/pub/Panasonic/Drivers/PBTS/manuals/OM_PT-AX200232C.pdf (3pages)
The only serial hacking I have done in the past was with a quad servo controller from a PC running homeseer, which worked good, but nothing like this...
Anyway, I have connected only ground and RX on the projector to the stamp, do I need to have a line back from the projector to the stamp? Flow Control? Start Stop Sync????
This is the simple test program I am running, it goes through a st232(??) that boosts it to rs232, tested on a serial LCD display at 9600
Any Pointers?
JasonT
Any Pointers?
' {$STAMP BS2sx} main: SEROUT 1, 240, [noparse][[/noparse]"STXPONETX"] 'turn it on PAUSE 5000 SEROUT 1, 240, [noparse][[/noparse]"STXISS:YUVETX"] 'switch to component PAUSE 5000 SEROUT 1, 240, [noparse][[/noparse]"STXISS:SVDETX"] 'switch to svideo PAUSE 5000 SEROUT 1, 240, [noparse][[/noparse]"STXISS:HD1ETX"] 'switch to HDMI 1 SLEEP 30 SEROUT 1, 240, [noparse][[/noparse]"STXPOFETX"] 'if nothing is on, turn the projector off. END
JasonT
Also, your STX and ETX are not right -- the app note says it's a ONE BYTE STX and one byte ETX -- that should have been a clue (the way you have it, "STX" is 3 bytes, as is ETX).
STX and ETX are actually ascii "characters" -- single bytes. STX is hex $02, ETX is hex $03, so a proper command string might be:
STX CON $02
ETX CON $03
SEROUT 1, 240, [noparse][[/noparse]STX, "PON", ETX] 'turn it on
PAUSE 5000
SEROUT 1, 240, [noparse][[/noparse]STX, "ISS:YUV", ETX] 'switch to component
PAUSE 5000
SEROUT 1, 240, [noparse][[/noparse]STX, "ISS:SVD, ETX] 'switch to svideo
PAUSE 5000
SEROUT 1, 240, [noparse][[/noparse]STX, "ISS:HD1", ETX] 'switch to HDMI 1
SLEEP 30
SEROUT 1, 240, [noparse][[/noparse]STX, "POF", ETX] 'if nothing is on, turn the projector off
Cool idea controlling a projector from a Stamp...
The on and off work
I tried both,
and
SEROUT 1, 240, [noparse][[/noparse]STX, "ISS",58,"YUV", ETX]
Pointers?
That was it, who would have thought that Input Signal Select would be abbreviated IIS??
Thanks to all, now the projector switches to the correct source based on the audio input selected on the amp.
Jason
