What's the best way to wait for a lock with a timout in assembly?
I just started hacking together a few programs in assembly. (already liking Propeller assembly FAR better than SX assembly) I'm adding an assembly program to an existing application that uses a shared serial port protected by a lock. I've passed my assembly all the information it needs to work. As stated in the subject, I'm wondering what the best way to wait for a lock to be free or a timeout to occur is in assembly?
My current code is below, I'm concerned that It won't deal with wraparounds of CNT properly.
Marty
Lunch cures all problems! have you had lunch?
Post Edited (Lawson) : 7/24/2008 10:00:00 PM GMT
:loop 'lots of code that we don't care about
mov timeout, cnt 'mark the current CNT
add timeout, wait_time 'move my mark far into the future
:ck_lock cmp timeout, CNT wc 'is CNT greater than "timeout"?
if_c jmp #:end_loop 'out of time, go to the end of the loop
lockset xtx_lock wc 'check if the TX lock is free and set the lock if it is free
if_c jmp #:ck_lock 'keep waiting till the lock is free
:end_loop jmp #:loop
'variables etc...
xtx_lock long 0-0
wait_time long 11000
timeout res 1
Marty
:bgn mov startTime,cnt ' Save start time :chk mov temp, cnt ' Get current time sub temp,startTime ' Now we have a time difference cmp temp,timeout wc ' Is difference less than timeout if_nc jmp #:endTime ' Timeout occurred lockset xtx_lock wc ' Check for lock available if_c jmp #:chk ' Lock now available lockclr xtx_lock ' Free the lock jmp #:bgn ' Start all over againNote that this requires that the timeout period be less than 2^32
clock cycles (about 50 seconds at 80MHz).
:chk mov temp, cnt ' Get current time sub temp,startTime ' Now we have a time difference cmp temp,wait_time wc ' Is difference less than timeoutYes, a very important basic coding principle. It should be at the start of every beginner's programming book. It applies to a whole world of threshold logic.
This is a good example of the difference between the far too simplistic educational examples and that of a really useful tool.
Evan
Marty
