GPS Tracker project ( BS2P + GPS module + JP Module + 16x2 LCD Display)
Hello all,
I just finished a summer project which is a GPS tracker demonstration program with data logging capacity. It uses BasicStamp 2P to interface with a GPS Module, JP Module and 16x2 LCD display. Code used is standard PBasic 2.5, it should work with most of the BasicStamp chips.
It can record GPS data to a MMC/SD card with latitude and longitude information. The data can be processed from Google Map at the website: http://www.gpsvisualizer.com. If you have Google Earth installed, the data also can be processed into a KML file (Google earth data file format) at the website: http://www.gpsvisualizer.com/map?form=googleearth
Main components:
(1) Basic Stamp 2P
Manufacturer:· www.parallax.com
Datasheet: http://www.parallax.com/tabid/440/Default.aspx
(2) GPS Module 40EBLS
Manufacturer:· www.mightygps.com
Datasheet: http://www.mightygps.com/oem/MightyGPS40EBLS.pdf
(3) JP Module·
Manufacturer: www.jianpingusa.com
····· ·Datasheet: http://www.jianpingusa.com/datasheet/JP%20Module%20Instruction.pdf
(4) 16x2 LCD Display
Manufacturer: http://www.femacorp.com/
Datasheet: http://www.femacorp.com/Products/LCD/Character%20Modules/Character%20Modules%20Index.htm
(1)·· Schematic
(2)·· Code
(3)·· Project photo
(4)·· Google Map
(5)·· Google earth map
Thanks to Parallax team and all forum users,
OldSpring (Author of the project)
Post Edited (OldSpring) : 7/23/2008 7:01:19 PM GMT
Main components:
(1) Basic Stamp 2P
(3) JP Module·
(1)·· Schematic
(2)·· Code
' File...... GPS Tracking Data Logger Demo
' Purpose... BS2P + JP Module + GPS Module + 16x2 LCD
' Author.... OldSpring
' Email..... [url=mailto:OldSprings@yahoo.com]OldSprings@yahoo.com[/url]
' Started...
' Updated... 18 July 2008
' {$STAMP BS2p}
' {$PBASIC 2.5}
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
#CASE BS2SX, BS2P
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
#CASE BS2PX
T2400 CON 1646
T4800 CON 813
T9600 CON 396
T19K2 CON 188
#ENDSELECT
' I/O Definitions
E PIN 1 'LCD Enable Pin
SOUT PIN 15 'Send command and data to JP Module
StatePin PIN 14
ResetPin PIN 13
GPS_In PIN 12 'GPS Data in
RecIndicator PIN 11 'GPS Data record Indicate
' Constants
' Variables
RecCount VAR Byte
x VAR Nib
GPSData VAR Byte(24) 'GPS Data from module
JP_Baud CON T19K2 ' 19200,8,N,1
GPS_Baud CON T4800 ' 4800,8,N,1
' LCD command
LcdCls CON $01 ' clear the LCD
LcdHome CON $02 ' move cursor to home
LcdLine1 CON $80 ' Lcd address for line 1
LcdLine2 CON $C0 ' Lcd address for line 2
Init_LCD:
PAUSE 1000 ' LCD self init
LCDCMD E, %00110000 ' wakeup
PAUSE 10
LCDCMD E, %00100000 ' set data for 4 bits
LCDCMD E, %00101000 ' set 2(4) line mode with 5x8 font
LCDCMD E, %00001100 ' turn cursor off
LCDCMD E, %00000110 ' auto increment cursor
'------------- First Screen ---------------
LCDCMD E, LcdCls
LCDOUT E, LcdLine1, [noparse][[/noparse]" GPS Tracking "]
LCDOUT E, LcdLine2, [noparse][[/noparse]" Data Logger "]
PAUSE 2000
' Format MMC/SD Card with FAT16
'Warning: Format will erase ALL data on your MMC/SD card!!!!
' GOSUB Formatting If formatting MMC/SD Card
GOSUB Init_JP_Module
' Initialization
Initialize:
RecCount = 0
' OUTPUT RecIndicator
LCDCMD E, LcdCls
LCDOUT E, LcdLine1, [noparse][[/noparse]"La:"]
LCDOUT E, LcdLine2, [noparse][[/noparse]"Lo:"]
' Main program
HIGH RecIndicator 'Turn LED ON
Main:
GOSUB DisplayData 'LCD Dispaly GPS Data
GOSUB RecordData 'Record Record Data
PAUSE 5000 'About per sample/per 5 sec.
GOTO Main
END
' Subroutines
RecordData:
GOSUB Rec_GPS_Data 'Get GPS Data for record
' Change GPS Data format "xxxx.xxxx,N,xxxxx.xxxx,W"
' to Google Earth Data format "xxxx.xxxx,-xxxxx.xxxx"
'DEBUG GPSData(11),CR
IF GPSData(11) = "N" THEN
GPSData(0) = " "
ELSE
GPSData(0) = "-"
ENDIF
'DEBUG GPSData(24),CR
IF GPSData(24) = "W" THEN
GPSData(12) = "-"
ELSE
GPSData(12) = " "
ENDIF
GPSData(11)= " "
'DEBUG STR GPSData\23,CR
SEROUT SOUT, JP_Baud, [noparse][[/noparse]STR GPSData\23, CR,"!!"] 'Data recording
RETURN
DisplayData:
GOSUB LCD_GPS_Data
LCDOUT E, LcdLine1 + 5, [noparse][[/noparse]STR GPSData\11]
FOR x = 0 TO 12
GPSData(x) = GPSData(x+12)
NEXT
LCDOUT E, LcdLine2 + 4, [noparse][[/noparse]STR GPSData\12]
RETURN
LCD_GPS_Time:
GPSData(6) = 0
SERIN GPS_In, GPS_Baud, [noparse][[/noparse]WAIT ("$GPRMC"), SKIP 1, STR GPSData\6]
RETURN
LCD_GPS_data:
GPSData(24) = 0
SERIN GPS_In, GPS_Baud, [noparse][[/noparse]WAIT ("$GPRMC"), SKIP 13, STR GPSData\24]
RETURN
Rec_GPS_data:
GPSData(24) = 0
SERIN GPS_In, GPS_Baud, [noparse][[/noparse]WAIT ("$GPRMC"), SKIP 12, STR GPSData\25]
RETURN
Formatting:
LCDCMD E, LcdCls
LCDOUT E, LcdLine1, [noparse][[/noparse]" Formatting... "]
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"MF!"] 'Format MMC/SD Card
PAUSE 50
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"OldSpring!!"] 'Volume label
PAUSE 1000
Waiting:
IF StatePin = 1 THEN
LCDOUT E, LcdLine1, [noparse][[/noparse]" Finished! "]
ELSE
PAUSE 1000
GOTO Waiting
ENDIF
RETURN
Init_JP_Module:
OUTPUT ResetPin
ResetPin = 0
PAUSE 1000
ResetPin = 1
PAUSE 1000
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"MA!"] 'Open data file
PAUSE 50
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"GPSTrack.CSV!!"] 'File Name
PAUSE 1000
IF StatePin = 0 THEN 'If file not find, create a new file
ResetPin = 0
PAUSE 1000
ResetPin = 1
PAUSE 1000
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"MC!"] 'Create a new file
PAUSE 50
PAUSE 1000
SEROUT SOUT, JP_Baud, [noparse][[/noparse]"Latitude,Longitude", CR,"!!"] 'Data title
PAUSE 1000
ENDIF
RETURN
(3)·· Project photo
(4)·· Google Map
