PCB Materials Suppliers
I need to make a custom PCB with the QFN propeller on it. I thought about using the DIP chip on some protoboard, but the wiring is just going to be too cumbersome. Instead, i want to make my own PCB's as prototypes and get some practice doing it at the same time. Anyone know of some good PCB material suppliers here in the USA?
www.fd.com.my
www.mercedes.com.my
As for the UV light, the one I mentioned warns about not being exposed to it for too long as it can cause burns on the eyes and skin(sounds like UV damage to me). Would this work?
These two videos look pretty straightforward..
www.youtube.com/watch?v=Q6WJqjVleG0&feature=related
www.youtube.com/watch?v=Vlui7s4lj7g&feature=related
I'll be waiting this thread myself to see what the "experts" have to say...
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
If you're going to roll your own PCBs, the QFN is an extremely poor package choice and will only lead to frustration. It's hard enough for a professional assembly house to solder these properly — and that's with the advantage of a soldermask, which homemade PCBs lack. I wouldn't even attempt it with a professionally-fabbed board. If you need something compact, the QFP is the package to consider. Even then, the QFP's lead pitch will be a challenge to etch with dependable results. Until you gain experience with making PCBs (which I recommend against, given the competitive pricing in the proto PCB market and the sheer curse-inducing mess of doing it yourself, not to mention chemical disposal issues and the rust-inducing fumes), the DIP would be a better place to start.
Have I dissuaded you? No? Well, then, ...
... extending my deepest sympathy in advance,
'Still some PropSTICK Kit bare PCBs left!
Now, WHERE do you buy this stuff? I've been searching and searching and can't find too much. BTW, how well does NaOH work as an etchant?
I have made my own PCBs in the past and I wouldn't want to attempt QFP layout.
If you have a frys near you they have PCB, etchant, etc.
JMH
tech.groups.yahoo.com/group/Homebrew_PCBs/
I've been making my own PCBs for about 40 years. I can solder QFN packages, although QFP is easier.
UV fluourescent tubes are safe and cheapest for PCB exposure, LEDs will be rather expensive. I use a simple exposure box made from some MDF and wood strips, with a sheet of glass, and two 12" tubes.
It takes me about 30 minutes to make a board.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 7/23/2008 5:43:00 AM GMT
If you're impatient, grab a breadboard. You can debug the software while you wait for the boards to get fabbed [noparse]:)[/noparse]
Most electronics suppliers sell replacement UV fluorescent tubes for use in the exposure units they sell.
Leon
But if you feel you need to learn the hard way, by all means have fun.
John
Inigo Montoya: Let me 'splain. (pause)
Inigo Montoya: No, there is too much. Let me sum up.
The Princess Bride (1987)
Has anyone here actually tried this?
OBC
Leon
Here is an example of the results I get.
Post Edited (Computer Geek 101) : 7/23/2008 2:17:46 PM GMT
I have an LPKF mill that I use to make some PCBs. It's expensive for the bits and the machine, but it makes nice boards.
Again after you go through the hassle of making the board, then the hassle of putting wires in all the vias (if you even can). It is not worth the hassle.
I usually use ExpressPCB because I already know the software. Then I purchase gerber files from them if I need a large quantity.
Bean.
"A government big enough to give you everything you want, is big enough to take away everything you·have."·· Thomas Jefferson
"It is our choices, Harry, that show what we truly are, far more than our abilities."·Dumbledore from Harry Potter
www.iElectronicDesigns.com
Making prototype boards is only $33 each or 5 for $100 at www.4PCB.com. I also suggest Mulitsims instead of eagle! Eagle is so limited. And i also agree with Phil!
A bit off topic but I am making at times small numbers of PCBs around 100 at at time and i am tired of soldering, is there a cheap way to solder the boards. I think I would need solder paste, an oven of some kind, and the solder mask? Please give me a bit of input.
...You get 3 boards for $51.
*IF* you truly do decide to do these boards yourself, you are going to spend $150 on supplies. (developers, etchants, tanks, carbide drill bits, precision drill)
Since you are just getting started, you need to figure out the following:
Development times
Exposure times
Etching times
Precision drilling
And you are going to have to worry about corrosion and maintaining this equipment.
I would honestly say that it will take you 3-4 weekends to get everything figured out (21 days)...and that is assuming that you can get the QFN footprint to etch without problems, and get your holes drilled correctly the first time.
5+ years ago, I could definately see the benefit in making your own circuitboards...but Why would you put in messy work for so little, when you can get 3 boards for $51 in as little as 3 days?
I was going to do the self-made pcb...but I think it would be much more beneficial to design the board on a tuesday, recieve 3 of them on Friday, and spend my time soldering the components on Saturday morning, and have blinking LED's by the afternoon.
It only took a couple of hours to get everything working. I haven't noticed any corrosion of the plastic food containers I use for etching, and no maintenance has been required.
Leon
Post Edited (Leon) : 7/23/2008 6:20:22 PM GMT
Leon,
What kind of success have you had with sodium hydroxide as the etchant? I ordered a pound last night and it should be here in a few days. For starters, I was thinking running up to fry's and grabbing a couple of "presensitized" CCB's. Are these the kind that have the photoresist already on them, or is this something else?
I use pre-coated boards, Fotoboard 2 rather than FR4. It's cheaper than FR4 and much easier to cut and drill, being made from a compressed paper core with thin fibreglass on the top and bottom.
Leon
You're correct: etchant doesn't corrode plastic tubs. But every steel tool in the workshop that's hanging or lying within twenty feet of the stuff will soon acquire a thin coat of rust. I know this from my own wretched experience.
Philldapill,
It's not too late to stop this madness. Out of all those who have responded to your posts, most (perhaps even all but one, LEON) have pointed out sound, logical reasons not to do this youself. I don't know if there are rehab centers that treat "gluttony for punishment". If there are, I'm sure Google will help you find one.
What's so hard about that? [noparse];)[/noparse]
