super carrier board and the lm2940 voltage reg
Hello all!
I have a super carrier board with a bs2px .. with the following attached/configured - all working-transmitting etc
-all pins 220 ohm protected
- pins 9 - 15 accessible for relay use on the other side of a uln2003 ( v++ wil be 12-15 volts, 12.5 average)
- I2C RTC from gravitech .. based on DS1340-33 IC.
- ADC 0831 after 150K/51K divider - (20 volt upper range)· - used to monitor raw voltage 12-17V range grom solar/wind
-912 Mhz transmitter/receiver - parallax
Other
- No relays at this point, but figure 12v 30-50 mA each x 4
- 4x20 LCD serial LCD on order (20-90mA)
Question, After doing a lot of forum searching after being concerned about current draw through the lm2940 5.0, I decide to feel the heat sink, and damn if it wasn't hot ... at 12.1 V+. I really don't want to unsolder it (but will if needed), my expected V+ range is 11 to 15 volt, mean at 12.5 (wind/solar powered and monitoring use) . Actuall current draw ·is ~ .1 A at 12V
should I regulate upstream with a LM7806 ? or just replace the reg? If I run upstream with another reg , any isues with my ADC? and its ground points?
FYI ... product descriptoin for super carrier is "On-board voltage regulator accepts 6-30 VDC, from wall-pack or battery "
add. note --- this is all hard wired at this point... [noparse]:)[/noparse]
Other
You could also add an "upstream" regulator, maybe an LM7808 which would produce 8V input for the super carrier board and reduct the "headroom" there to only 3V.
The ground points are all going to be in common. You'll want to be careful about where you tie in the ADC's analog ground (to avoid ground loops).
most likely the DE=SW050
http://www.dimensionengineering.com/datasheets/DE-SW0XX.pdf
I just clipped the pins on the original lm2940,·soldered wires to the remaining posts comming off the board which then went to the new reg
pins match 1:1
