Controlling servos connected to a PSC-USB using Visual Basic code
I am developing an application where I got to control few servo motors connected to the Parallax Servo Controller-USB using visual basic code.I have connected my PSC to PC through USB port.And also I have written code in Visual Basic using .net to send data to PSC through USB port.I am sending PSC serial commands in the form of text using the above code from my PC to the PSC to control the servos as the PSC is having a USB to serial converter chip on it which directs the data at USB port to serial port.But due to some reason ,there is no functioning of the servos in this way.I don't know if I am following the correct procedure.Kindly help me to comeout with a good solution.
Thanks in advance.....Any suggestions are greatly appreciated
- Stephen
http://forums.parallax.com/showthread.php?p=546069
