Powering the Prop directly from a 5v system?
Wouldn't it be possible to tie the Vcc pins to a 5v line via a voltage divider? It *sounds* like it would work, although I am undoubtedly missing something (current draw possibly). I cannot see a direct need for this since an additional regulator adds only three components, but if the Prop is the only 3.3v component in a system, it might have its uses.
Sorry to say that unless you plan to use a zener diode to clamp the voltage at 3.3 volts this idea will not work. Use a LDO (low drop out) regulator to get the 3v3.
Cheers
The Propeller draws widely varying current depending on the clock speed, how many cogs are running, how much I/O current is needed, etc. The mostly likely scenario is that you'll destroy the Propeller from too much voltage. I strongly suggest that you try out ideas like this on paper. It's easy enough to do. The Propeller datasheet has most of the information you'd need.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Leon
'Still some PropSTICK Kit bare PCBs left!
That's what I was thinking. If it would have worked then I could save a dollar or two. I'd much rather ask than fry my Prop.
