16+ Bit Counter Based ADC
So I was wondering has anyone tried or know if you can use 16 or greater bit ADC conversion using the counter system to convert it. Under the Counters doc it gives an example but only shows up to 14bit. I was unsure if there was a hidden reason for this or just the longer sampling time to achieve it.
I was wondering if it would still work if you just placed 16 in the changeable value under the ADC example?
If anyone knows please let me know.
Thank you for your time.
TJ
TJ
If you want high accuracy, you really have to use an external ADC chip, one designed to give the accuracy you want. Most general purpose chips will only provide up to 12 bits and that's hard enough to get without careful design.
