Hacking a 5" B/W Television
· I tried the digital potentiometer experiments in the What's a Microcontroller? kit and I was looking
for an application for the digital pot.·· I took apart a Colby 5" B/W portable TV and found that the
TV tuner uses a 100K pot.· I was thinking of converting the TV to digital tuning with preset station
recall and IR remote control.· I don't know the wattage rating of the pot in question.· I checked
different sites for an 8-Pin DIP 100K digital potentiometer with UP/DOWN interface and I found that the current ratings are very low for these chips- most are less than 1mA.· Does anyone here know
if a digital pot would work in this application?·
The most general indicators of a pot's power requirements are its actual size and what what it is connected to. I suppose that you could stage the digital pot to control more than 1ma with a 2n2222 transistor [noparse][[/noparse]100ma maybe] or an op amp [noparse][[/noparse]25ma or so, but more predictable]. With either device, one doesn't actually have to use a matching digital pot, but the output must be over the same effective range as the original pot.
I suspect the extremes of the 100k pots range are not used and that it goes to a VCO chip [noparse][[/noparse]voltage controlled oscillator]. One milliamp just might work in this context.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
If the pot is being used as a divider with the wiper being the output to a high-impedance load (most likely scenario), you should have no problem. OTOH, if a voltage is applied to the wiper or the wiper is driving a low-impedance load, you will have to compute the worst-case current based on the wiper's extreme settings.
One thing to consider with a digital pot is its resolution. With 256 different positions, for example, will you be guaranteed that each station you want to view will correspond exactly to one of them? I have my doubts. Another thing to consider is the voltage range for the pot terminals. This is typically limited to Vss-to-Vdd. So you will want to make sure the device you pick can handle the voltages present in the TV.
'Still some PropSTICK Kit bare PCBs left!
