Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
About PING ultrasonic sensor — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
pumaju
9
2008-07-20 00:25
edited 2008-07-20 16:55
in
Robotics
hi,
i have a PING ultrasonic sensor and i see that in front, it has a led called "ACT", i want to know what does this LED means??, when this LED turn on or turn off??
thanks
iDave
252
2008-07-20 01:00
edited 2008-07-20 01:00
It simply means it just shot an ultrasonic burst. Goes on briefly when the pulsout command has run in your program. That's all
"THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
pumaju
9
2008-07-20 02:12
edited 2008-07-20 02:12
if this LED does not anything (dont flash), means that burst is not send it??
what was wrong??
Franklin
4,747
2008-07-20 02:36
edited 2008-07-20 02:36
Could be your code or your wiring or something might be broken, it's hard to tell without your code and a picture of how you wired thing together.
- Stephen
pumaju
9
2008-07-20 16:55
my ping now works, i had a 3.3v power supply instead a 5v one, i thought that 3.3v work, but it did not
thanks
Sign In
Register
to comment.
what was wrong??
- Stephen
thanks
