LCD Gurus?
Im looking for a touchscreen LCD module, not much out there, in my search I've come across 2 componets I think might work together, but I dont know much about LCDs other than serial commands.
http://microcontrollershop.com/product_info.php?cPath=301_189&products_id=2416
Drive/Control any QVGA (320X240)monochrome graphic display with no graphic controller built-in
GLC-M21 Board Features
And this screen
http://cgi.ebay.com/NEW-Data-Intl-5-7-inch-320-X-240-LCD-DG320MONO-DG-32240_W0QQitemZ270255203326QQihZ017QQcategoryZ26206QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#
NEW Data Intl 5.7 inch 320 X 240 LCD DG320MONO DG-32240
The Controller has these relevant pins
VEE 40 O (Analog) LCD negative bias
DisOFF 47 O Display control signal H: Display On L: display OFF (LCD
interface)
FLM 48 O First line marker ( LCD interface)
YSCL 49 O Latches the frame data into input shift registers of the Y- drivers
(LCD interface)
WF 50 O LCD panel backpanel bias signal (LCD interface)
LP 51 O Data latch signal (LCD interface)
XECL 52 O Control signal for LCD X- drivers (LCD interface)
CP 53 O Clock signal for shifting data (LCD interface)
XD0-XD3 57 - 54 Display Data (LCD interface)
3.3V-OUT 58 PWR OUT 3.3V supply output for driving 3.3V displays
And the screen lists this pinout (plus a visible 4 wire resistive touch screen connector)
- RS232 TTL interface
- RS422/485 interface support
- Drives 5V and 3.3V displays
- Digitally controlled contrast
- Digitally controlled brightness (LED backLight)
- Digitally controlled backlight ON/OFF
- 512K Bytes EEPROM for fonts, bitmaps and GUI storage
- 4 wire resistive touch screen controller
And this screen
interface)
(LCD interface)
Controller 47 (Disoff) to Display 5 (Disp off)
C48 (FLM) to D6 (First Line Marker)
C51 (Data Latch) to D8 (Data Latch)
C53 to D9 (Clock Shifting Signal) to (Data Shift) ???? Is that right
C54-C57 to D1-D4 (Display Data)
Leaves me with these unknowns
C40 VEE - LCD Negative Bias
C49 YSCL - Y driver Latch
C50 LCD backpanel Bias Signal
C52 XECL - X driver control signal
D10 VDD - power supply for logic
D11 VSS GND
D12 VEE Power Supply for Logic
D13 V0 Operating Voltage LCD Driving
D14 Front pannel ground
Some of those I get, but others I dunno, like the X and Y drivers
So are there any Gurus that can tell me, is it a decent gamble to see if these two will work together?
This is not a bad deal, its another $140 ($275), basically a complete package, LCD, controller, Buzzer, 3 LED's Backlight transformer, connectors for the LCD and touchscreen, a nice connector for the external connections. It also comes with thier software package for GUI design.
I noticed something going through the datasheets for it, This is the pinout for the board\LCD connector, it is exactly backwards from the Ebay screen, so I'm quite positive the Ebay screen would work just fine, problem is I would have to try and connect to the flat ribbon connectors.
(controller pinout)
1 GND
2 VEE
3 VEE
4 GND
5 VDD
6 CP
7 LP
8 NC
9 FLM
10 DisOFF
11 XD3
12 XD2
13 XD1
14 XD0
So I guess I have to make a decision. $140 more for a cleaner package with a couple of leds and a buzzer, and most notably, the software, or maybe $20 shipped for the ebay screen. Anyone who is looking for a touchscreen interface, this looks like a winner, a TON of neat features in the controller, a must see if you're in the market.
Anyway, im still deciding. I think the hardest part for me using the Ebay screen would be connecting the FFC cables, I did a quick search and cant find any connectors.
BTW, if people are wondering why im talking to myself so much, I see people are looking, so someone might be interested, and I hate when I search for a problem only to find an old thread that someone never posted thier solutions.
Okay, whats going on here, yesterday I know someone posted something with a datasheet, but when I came back to look closer, it was gone, google even chached it, it comes up in a google search. Now PF says the thread was updated by Franklin at 6:59AM, but there are no posts. Wierd...
You· are not loosing your mind there was a post it was from me I remove it after i saw that you had the same data sheet·I found
I think that this might be your best way to go you have every thing you need and see if one of the ones on ebay will work or not
··Thanks for any·
Sam
http://www.haidartechnology.com/uploads/Brochure_GUI_New.pdf
Bottom line, that program looks like it would knock weeks off my project. I think this is going to go into a home automation project. Starting with thermostat, but I'll have tabs, one for security, one for some other stuff, Ive got a BS2p40, and if this thing only takes the 2 serial lines, it will leave 40 pins open for me to work with.
Please post your project when your done
I would like to see what you come up with
·I like your
··Thanks for any·
Sam
They asked if I wanted to cancel my order, I tol them I was very disapointed and asked them if they would include the software since I was mislead, and I really did spend a lot of time last weekend reading all the data sheets and instruction manuals they had on it.
Adam,
The Mosaic-M320240570T Graphical Display Kit is a complete graphical display solution that envelopes the Serial LCD 320 x 240 Monochrome Graphic Display Controller (GLC-M21), the GooyLCD IDE interfacing software, EVL-GML106 with RS232 interface, and a 5.7” 320X240 pixels STN LCD with CCFL blue backlight and 4-wire touch screen.
http://microcontrollershop.com/product_info.php?products_id=2426
All for only US$450.00.
For just the software, LCD display, and the LCD controller:
GUI LCD Controller Module w/ 320x240 STN (Super Twisted Nematic) - US$275.00
http://microcontrollershop.com/product_info.php?products_id=2418
The product you mention below could in fact work with the the Serial LCD (320 x 240) Monochrome Graphic Display Controller (GLC-M21), but you will not have the GooyLCD IDE software, which is an excellent software tool for creating a professional graphical user interface on your PC without the need for constant downloading or trial and error sessions. And, as you mention, it is a gamble. With our products, we provide technical assistance to ensure our customers get their purchased products working out of the box.
I would recommend you choose from one of the above products, which may very well save you time and money in the long run. In addition, we have a 15 day satisfaction guarantee with our products. Within 15 days of receiving the products, if you are not satisfied, you may return the merchandise for a full refund minus shipping costs.
I hope this information is helpful. If you have any additional questions, please do not hesitate to follow up with us.
Best Regards,
Justin
MicroController Pros Corporation
http://myfiero.com/uploads/13114_.jpg
If I do get it, I will be ordering directly from the manufacturer.
http://cubloc.com/product/03_01.php
John Bond
30-Day Money-Back Guarantee
Any Haidar Technology product may be returned
within 30 days of purchase for a full refund of the
price paid for the product being returned. If you are
not satisfied, or chose the wrong product by mistake,
you do not have to keep it.
I told them I would accept thier offer of 1/2 off the software, and evaluate the product, if I didnt meet my needs, I would return it per thier return agreement. They are saying it is at thier discresion, they will not refund software, and they would not refund the product for me in my instance.
I am seriosuly considering contacting the BBB and any other agencies and reporting all of this false advertisement.
I will keep you updated. It would be a very interesting product, perhaps I have been spoiled by the Simmetry displays, they came preloaded with all those interfaces, powerful utilities, and were really cheap. These are something like 4x bigger than those though.
John, I'll look at that product.
I'll give·a nice review of features and performance of whatever I use, as of right now it looks like I will be making a decision this weekend.
Ive got one other choice http://www.smarthome.com/78550.html·at $90. The visible dimensions seem to be only a little smaller, but resolution is only 160x80
Post Edited (GICU812) : 7/25/2008 9:19:02 PM GMT
