cheap serial sirf iii gps from a usb unit?
Sorry one more question: has anyone found a source of cheap serial sirf iii or other -159 db gps sensors inside a USB gps unit? I have a Globalsat gps mouse device but when I removed the screws, there's a magnetic and a solid block there. I can access the USB port but not the serial connection. Are there any other gps units out there that are inexpensive source of gps boards? The Globalsat sirf III usb unit is only $35 or so from buygpsnow rather than the higher priced, lower sensitivity models out there.
Would be nice if the unit were compatible with 3.3V too...
