Detecting low voltage input — Parallax Forums
computer guycomputer guy Posts: 1,113
edited 2008-07-22 05:39 in BASIC Stamp
I have a switch that outputs 1.2v when pushed and 0v when released.
If I want the BS2 to detect the change I have to use a transistor right.
What value components would I use and will this circuit do the job.
Version1
Version2
Building Blocks To The Propeller Chip A web site designed to help people who are new to the propeller chip.
Guitar Hero controller using the prop (WIP) --> HERE
399 x 304 - 4K
399 x 260 - 4K
    edited 2008-07-18 04:39
    Neither version is quite right. Version 1 won't work at all. It's what's called an emitter follower. The resistor in the emitter lead provides negative feedback for the base current and, with a 1.2V input, may prevent the transistor from turning on depending on its value.
    Version 2 should work, but needs a resistor in series with the base lead to prevent the transistor from drawing too much current from the 1.2V input. 0.5mA is more than enough and a 1K resistor is about right. The collector resistor should be something like 1K for a 5mA collector current.
  • computer guycomputer guy Posts: 1,113
    edited 2008-07-18 04:55
    So this should work.
    Version3
    474 x 260 - 5K
    edited 2008-07-18 06:33
    computer guy,
    You may not even need a transistor at all... A simple voltage divider might work.
             15K       3.3K
    5V >----/\/\---o---/\/\----< 0V to 1.2V input
                   o-----------> To I/O Pin
    Since the I/O pin has a threshold of 1.4 Volts·.. When the input voltage is 0V, the voltage divider produces about 0.9 Volts at the input to the I/O Pin.· When the input voltage is 1.2V, the voltage divider produces about 1.88 Volts at the input to the I/O Pin.
    Beau Schwabe
    IC Layout Engineer
  • NosePickerNosePicker Posts: 54
    edited 2008-07-18 11:24
    Beau, can you help me understand how you calculated the 0.9v and the 1.88v. I have a simular issue but I am wondering if those size resistors will work if my voltage was only 1.0v instead of 1.2v?
    NosePicker
    edited 2008-07-18 16:09
    NosePicker,
    You can use the standard voltage divider rule, but I prefer to use a derivative of that and find my current through the system first.· To do this you take the difference in voltage divided by the total amount of resistance.
    In this example, the total amount of resistance will be fixed at 18.3K ( <-- 15K + 3.3K )
    So when the input signal is 0V, the difference in voltage is 5V and the current is 273 micro Amps. ( <-- 5V / 18.3K)
    Likewise, when the input signal is 1.2V, the difference in voltage is 3.8V and the current is 208 micro Amps. ( <-- 3.8V / 18.3K)
    Now, the resistor of interest is the 3.3K ... If you take the current calculated above for a 0V input, and multiply it by the resistor value of 3.3K you get 0.901 Volts across that resistor.
    Doing the same thing with the 1.2V input you get 0.68 Volts across that resistor·... But wait a minute! That's not the 1.88 Volts I mentioned earlier.· Take a closer look, you are now biasing the input with 1.2 Volts that gets "ADDED" to the 0.686 Volts.· 1.2V + 0.68V = 1.88V that the I/O "sees".
    With those resistor values, I think that a 1V signal would still be enough to clear the 1.4V I/O threshold.· A 1 Volt input equates to·1.72V that the I/O would "see".
    Beau Schwabe
    IC Layout Engineer
  • Dave-WDave-W Posts: 94
    edited 2008-07-19 18:26
    All,
    I think version 3 would work the best above all other ideas, but I would add a 10k resistor from the input·of the transistor to ground to prevent false trigger. I am assuming that when the switch is not pressed it is an open circuit and not zero volts. This open circuit would also prevent the resistor divider from working. If I were to use the resistor divider I would have·replaced the 3.3k with a 1N4148 assuming the input is at ground potential when open and not floating.
    D. A. Wreski
    The input of the transistor is at 1.2v when the button attached is released and 0v when pressed.
