Gears always fall in to two sources - buy and scrounge. I have a box of scrounged parts from about six cannibalized CD and DVD players.
Buying gears in small quantities really gets hugely expensive. The problem is that the industrial·suppliers have to keep a few of everything in stock or build up a huge network. That isn't easy.
The Japanese toy manufacturer Tamiya seems to be the only source for both. They have complete gearboxes of several sorts. Some are two independent axles, some are one axle, and there is even a worm-drive. They have devices with spur and crown gears. If there is an outlet that sells Tamiya, they may also have sets of spur nd crown gears to R/C autos as hobbyist like to play with different ratios in competitions.
Everything about gears is related to torque. So you are going to eventually have to consider the shaft size as well as the gear AND how the gear is fixed in place.
Low torque and tiny shaft, hobby motor are often friction fit, but some have set screws.
Higher torque and tiny , like the propeller on R/C electrics connect with a collet.
1/2 horsepower and 1'2" shaft, like V belt drive connects with a set screw or two.
Extreme power moves you up to shafts and gears with a keyway slot.
These days, you can handle low torque and medium torque with a glue. Locktite has several different strengths and the strongest may be useful for setting gears.· Epoxy and super glue are other choices.
Of course with all those gears and shafts, you may want bearings. For small stuff, just use a bronze insert bearing as ball-bearing are quite expensive.
It's sunny and warm here. It is always sunny and warm here.... (unless a typhoon blows through).
Tropically, G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
Thanks guy's for the sites. I'll look them over to see if there is anything I can use for my project. I've looked the net over for many countless hours with no luck as of yet. Looks like I might end up buying a diviving head and a gear cutter to end up with what I need. Just another toy for my milling machine. Thank you all for your help....
I don't see crown gears, but I do see miter or bevel gear sets.
you can look at mcmaster-carr for the same kind of thing too.
Look around a bit.
(Can Beckius do gears?)
'Still some PropSTICK Kit bare PCBs left!
Post Edited (Phil Pilgrim (PhiPi)) : 7/17/2008 4:48:36 AM GMT
Post Edited (Kramer) : 7/17/2008 1:52:36 PM GMT
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Whit+
Twisted Pair....
