I'm having trouble operating the wheel kit using the command set.
I'm having trouble operating the wheel kit using the command set. To keep it simple, I'm down to one motor, an HB-25 and the encoder. I'm using a BS2 as the controller.
If I connect the controller directly to the HB-25 it works as expected using the HB-25 sample program for the BS2.
However if I connect through the encoder to the HB-25, using the Wheel kit example program (Position_Controller_Test_Interface.bs2), nothing happens.
I've run a servo lead from servo connector 12 on the BOE to the header marked "To Controller" on the encoder board.
I've also run a two wire connector (ground and signal) from the header marked "To HB-25" on the encoder board to the HB-25.
Both jumpers are installed on the encoder board so the ID is 1.
Does anyone have any ideas on what I'm doing wrong?
Thanks, Harry
[noparse][[/noparse]Descriptive Subject Added]
Thanks, Harry
