Robo House
Hello, so i have begun planning on my masterpiece project which in short is automating most of my house. I want to take care of security, monitor, interact and send preprogrammed commands to my rover robot. That is the first stage, but i eventually want to incorporate controlling user preferences around the house using RFID tags mounted below our watches. By user preferences i mean water tempature, access to only certain rooms via the tags ect.
For security i plan to use:
RFID tags and scanners
Occupancy (or motion) detectors
IR sensors
Light sensors
possibly a soft air gun mounted on the rover
For monitoring and automation:
The above and;
Tempature sensors
humidity sensor
So i am looking for any help or comments you have other then that this is a huge project. This isn`t artificial intelligence or anything though just basic sensors and basic commands, just on a large scale. What micro controller should i use? I am most comfortable programming BS2`s, but i realize that this would probably work best with a Propeller chip even though i have never really worked with it. Also i need some sort of cheep way of communication, because running wires around will work for most but not for all. I am thinking i will need to have a central hub ran by either a BS2 or a Propeller and a couple BS1`s throughout the house for things that need to be wireless.
IR sensors
Light sensors
The above and;
Tempature sensors
humidity sensor
You could certainly use a network of BS2s with an occasional BS1 for something simple. I'd suggest using xBee modules since they're small and low power and can be networked easily.
I'm biased in favor of using the Propeller chip for the central control. At $20 a pop for the Protoboard, the Propeller would work nicely for the peripheral units even though that might be overkill. The only thing cheaper would be to use SX Protoboards for those, programmed in SX/B. You could use those for the central controller, but the Propeller is more capable and it's easy to include a full keyboard and VGA or TV display.
If you can run simple wiring (a pair of wires (twisted pair)), you can save the cost of the wireless modules. Make it two twisted pairs and you can distribute power as well (probably at 6-9V)
