Propeller Chip as Mass Storage USB Device ?
I would like to implement a Propeller-based device that can act as a Mass Storage Class Compliant USB device.
I currently have a Propeller-based board (uOLED-96-PROP) and a Prop Plug.
Is this possible with a Prop Plug?
Are there examples of how to do this?
Thanks.
Thanks.
To implement Mass Storage you need to be able to use USB_BULK transfers. To use USB_BULK transfers you need to be able to do either HIGH_SPEED or FULL_SPEED and the Prop is only fast enough to do LOW_SPEED.
You also can't change the usb characteristics of the ftdi chip on the Prop Plug.
Sorry to rain on your parade [noparse]:)[/noparse].
You may be able to use one of the other available hardware USB SIO chips out there (in fact I'm _sure_ you could) .. so it's not easy, but with additional hardware it's likely to be possible.
A bit like having to use an external Ethernet controller chip to get network connectivity.
MacOS and Windows actually ignore the speed rating of the device and allow you to use USB_BULK for LOW_SPEED devices (limited to transfers of 8 bytes) but your media speed at absolute *best* case is going to be slightly less than 8kb per second, in addition to violating numerous USB specifications. Check my CDC-ACM USB driver for an example (A forum search will bring it up - its not in the object exchange), but don't think its going to be easy (and it _won't_ work on Linux).
Pull my finger!
Is I2C the right way to go?
Would SPI work?
Other?
Thanks.
Sure I2C, SPI, Parallel Data Bus, Async, One Wire.. name your poison?
I'm assuming if you are wanting Mass Storage that you want things to go fast, but you are not really giving us anything to work with..
I guess you want your propeller to look like a block device to the PC.. why ?
Pull my finger!
Stephen
"Fast" is not important.
I am making quick and dirty prototype that has a uOLED-96-PROP displaying a slideshow of BMPs. I want to be able to transfer small images to the propeller over USB using a standard USB device type (HID, mass storage, keyboard, mouse). The Prop Plug won't work for me because i want to plug this into a USB host that does not have drivers for serial to USB -- but the USB host does have drivers for HID, mass storage, keyboard, and mouse.
The Atmel's AT90USBKey is able to look like a HID, mouse, and mass storage. My current plan is to use the propeller to run the display and the AT90USBKey to handle USB communications. If getting one I2C or SPI working is not straightforward with a couple pieces of wet string [noparse];)[/noparse] then I may move over to using the AT90USBKey to drive the display.
I am open to suggestions. Thanks for the help.
I want to be able to transfer new images to it over USB from a non-PC USB host that only has drivers for HID, mass storage, mouse, and keyboard... and I don't want to write drivers for this non-PC USB host.
HID is certainly doable. Check the "California dreamin'" USB stuff for a quick HID compliant keyboard emulator.
I _can_ say that HID is a very different beast on Linux, Windows and MacOS and it's quite a pain to be consistent across the platforms.
It's not incredibly difficult to get a "generic HID" type of device whipped up and talk to it using feature reports.
Depends on what your "host" is I guess..
I'm currently doing my development on linux in Virtualbox, with the virtual serial port connected to a unix socket. On the other end of the unix socket is an application that pretends to be a propeller to suck the code out of the Propeller Tool when I press F8. It then loads it into a propeller over a USB HID link.. so yes, it's doable [noparse]:)[/noparse]
Pull my finger!
It can either read/write ram *or* eeprom directly. Can't load eeprom from ram or ram from eeprom though. No space in the cog left.
Pull my finger!
MCHP's intro pages on their USB stuff: http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2651¶m=en534497
