I am using the Prop to control servo motors and I have a question.
Hello,·
I have a problem that is not linked with the Propeller itself and I do not know what should be the forum for my post...
I have a servo and a turet and I want the turet facing 100% foward (servo position 0) but when I connect the turet to the servo shaft then because of the theets on the shaft I am always a litle bit on the left or on the right......
Any idea on how to setup the servo in order to have the turet facing 100% forward with servo position 0?· (of course the issue is mechanical but if there is a way to tell to the servo what is the new physical position 0???).
thanks a lot.
jm.··
thanks a lot.
jm.··
If the servo is always going to the same "slightly off" angle, Mike's technique will work.
Paul Baker
I should be able to manage it.
Thanks again!
