HB25 and homemade power servo?
Does anybody have an idea on how I can attach a pot to the HB25 to give the gearmotor a position reference, just like a normal servo?
I would like to make a more powerful servo, but need some advice on how to make it·like a normal servo.
On the new gearmotor and wheel setup that parallax has, it uses an encoder. It doesn't attach to the HB25 or does it go to the microcontroller?
Secondly, do you have any other refences to a higher amped controller with this feedback ability?
2) I don't what the max. current is. You might have to call Pololu to make sure.
http://spooksterville.com/site/index.php?option=com_content&task=view&id=16&Itemid=25
http://www.cherrycorp.com/english/sensors/an8.htm
I am using the 360 model feeding into a 10 bit ADC which gives a range of about 104 to 912 spread over an entire rotation. Works great to make what is essentially a way big servo.
Mind sharing where you got those, and for how much?
-Parsko
sensor with rotary magnet about $33 : 540-CU103602
the connector (you have to have this ~ $3) : 829-12162185
crimp-on female parts - they call them terminals : 829-12124075
It took me 3 orders to get all the parts. You are advised. These work great - you just have to read the analog signal.
Quitman
