EMIC eliminate background noise
Hello all,
I have the EMIC module output terminals connected to my stereo (EMIC and Stamp2 are on a BOE).
There is some humming in the background.· I checked the forum and the only thing I understood - being a novice at this - was to connect a capacitor on the EMIC's output.
Is there anything else I can do to eliminate or reduce the background noise?
Shmow
Shmow
It doesn't look like the BOE has a ground terminal.
I never thought to use the analog out.
If I was to use that connection with the audio cable then
I would connect the + terminal (red) on my stereo to the analog output on the EMIC and
the - terminal (black) on the stereo·to the gnd on the EMIc. Is this correct?
Shmow
Now, if you had RCA inputs (little concentric circle connectors) then the inner pin should connect to the EMIC analog, and the outer ring should connect to the EMIC ground.
I will wire those in tonight.
Thanks for your help.
Shmow
the other end of this cable -·positive to the analog out and the negative to the GND.
There is still a humming noise.
I connected a capacitor in series with the analog output of the
EMIC, trying different values·(22·to 100 microF).
I don't think the clarity won't get any better.· I'm trying to get it so people in
a small warehouse can hear her voice.
Shmow
Deno
PS...I have this problem (but live with it) on my talking sprinkler system where I am using a 'wall wart' for power.
