PBasic Math
Hello,
I am using a BSII, an ADC ic, and a tsl253 light to voltage sensor to create a colorimeter. I have a parallax LCD module (serial) and everything works great. I get 10 reading (3.94), but I need to average these readings and then display to the lcd. I need help with the math for pbasic. All my values are between 0.00 and 4.00.
Curtis
Curtis
Since the BS doesn't have floating point math, I'll assume that the range you quote is converted from integer to floating point.
Also assuming you are using a 12 bit ADC, the maximum reading would be 4095, which multiplied by ten is a max of 40950, which fits in a word sized var. So, all you need to do is accumulate the readings in a word size var, then divide by ten. Then do whatever math you are doing now.
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
