rs-232 question
Do most PC ports and machines that take rs-232 input work fine with 0-3V ttl or 0-5V ttl or do you need some sort of external driver (say a maxim rs-232 chip)?
I assume the best that can happen is that it doesn't work but the worst is that the incoming +/-10V or whatever the rs-232 spec is will fry the inputs of the BS.
Are there any quick and easy solutions to convert 0-3.3V ttl to rs-232 without an external voltage supply?
Thanks for all the help.
3.3V is just barely high enough to satisfy an RS232 input. You're really better off using a MAX3232 or equivalent to convert 3.3V/0V logic levels to RS232 signal levels. The trick that the Stamp uses can also be used with the Propeller for RS232 inputs, not reliably for outputs. There is a 3 transistor converter for the Propeller as well. It "steals" power from the RS232 receive line (from the PC or whatever's transmit line) to provide an idle voltage for the RS232 transmit line (to the PC or other device).
Isn't it silly that that the chip requires capacitors but they don't surface mount those things or make them somehow in silicon? Would save me a ton of soldering time on a large number of components...
Thanks for the help!
MAX-233 is the all-in-one device.
It's hard to make large capacitors on silicon. The MAX3233 can't deliver as much current as quickly to a long or relatively high capacitance load as the MAX3232 with its external capacitors. Including discrete capacitors in a hybrid package would make the thing much more expensive.
Post Edited (Mike Green) : 7/14/2008 3:00:10 PM GMT
