Is an onboard compiler possible? — Parallax Forums
edited 2008-07-15 14:38 in Propeller 1
I'm curious if some of the expert level programmers here
feel as if an on-board compiler might be possible for the
propeller?
Something that could read a .spin text file and generate
a binary? Do we have enough access to the source to
create such a tool?
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
  • RaymanRayman Posts: 15,955
    edited 2008-07-13 16:35
    I think it could be done using an SD card. Then, the job can be broken into several steps with intermediate output files...
  • heaterheater Posts: 3,370
    edited 2008-07-13 18:03
    Just last night I was reading some history of Unix and the C language vestein.arb-phys.uni-dortmund.de/~wb/chist.html
    They started out with a DEC PDP-7 mini computer with 8K of 18 bit words and started to make big progress when they got a PDP-11 with 24K bytes RAM.
    So I think with an SD card we are in with a chance.
    edited 2008-07-13 18:45
    At one point I was doing some experimentation for an on-Prop Basic compiler. I got a full expression parser and some simple statements implemented before I ran out of room. The plan was to load the source program into a 32K piece of EEPROM from an SD card file and compile that to intermediate code in a 2nd 32K piece of EEPROM with the 3rd 32K piece containing the dictionary. This was to allow easy and fast random access for fixups and searches. It's clearly doable, but a large and time-consuming project. I won't have time this summer to work on it, but maybe late fall ...
  • AleAle Posts: 2,363
    edited 2008-07-14 04:53
    Well,
    that was a fine article. If they did it... why we cannot ? It all depends on what you want. Full-blown C is not possible, but some cut down version may well be, as they explain.
  • Matthew HayMatthew Hay Posts: 63
    edited 2008-07-14 06:00
    Actually this is something that I've been thinking of working on using a ps2 keyboard, vga monitor, and SD card.
    My crazy idea is to write a modified spin interpreter and instead of reading from HUB ram reads directly from the SD card, which would allow a rather large file to be interpreted but ofcourse this would be rather slow.
    edited 2008-07-14 09:17
    If you read ahead blocks... caching and so on, it may not be that slow,
    edited 2008-07-14 11:50
    Somewhere in this forum Chip let out that one of his aims/dreams was exactly to have a stand alone development system for the propeller free of any dependence on a PC. As he is rumoured to have written the spin compiler in Intel assembler I'm sure he could reproduce it in Prop assembler especially with the help of some LMM technology. I presume he was thinking ahead to the Prop II where a little more RAM would help a lot. So I'm not sure I'd want to try to build a Spin compiler in competition.
    But for now what about a Prop assembler that runs on the Prop ? That must be doable after all old CP/M systems could rebuild themselves in 24K bytes. Keep it simple, all symbols to be limited to say 12 characters so we don't need to worry about strings. String comparison becomes compare of three longs. What ever tricks it takes. The Prop instructions are very regular so this helps a lot.
    Of course the first thing needed is an editor. Forget about free form text editing. Make it line and field based, lable, condition, instruction, source, destination, effects. Possibly comments hanging of the end. In fact the editor could pretty much "assemble" straight into memory as you type.
    Looking up a bit BASIC must be possible. Sinclair had a basic running on the ZX81 with 16K ROM and 16K RAM. This had the interesting idea that for example hitting G on the keyboard in programming mode produced GOTO in the basic. So it tokenized as you typed !
    Just thinking.....
    edited 2008-07-14 12:10
    Sinclair's integer BASIC was 4 Kbytes. Sinclair's FP Basic (ZX81 and clones) was 8 KBytes. Spectrum's BASIC was 16 kbytes. Marvels of compactness. The interpreter is 2 kbytes (Spin) a simple editor and compiler (statement by statement like BASIC should fit in another 2 Kbytes...
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-07-14 12:15
    I did a very basic assembler but I never got the labels working properly and it never saved anything. It basically took the users input and turned it directly into the instructions. Good luck finding it in the forums though. The thread title was something like "on prop assembler". If you can't find it I can post it again. I believe that one of the forth variants for the prop has an assembler as well. Personally I think that an on prop development would be great but I don't have the time at the moment...
    Don't forget femtoBasic and TinyBasic (on Hydra CD).
  • JoannaKJoannaK Posts: 44
    edited 2008-07-14 12:22
    Possibility of onboard compiling depends a lot of programming language used.. these newer things (like Java and C++) tend to be overly complex for nice in.chip system.
    Forth systems have compiler on board (try PropellerForth, only 10kilobytes), and the size varies depending what other features are needed. PF uses simple serial port IO for console and have no VGA/SD-card modules inbuild nor any editor in itself. It has nice words for EEprom accessing so it wiould be possible to expand it with an Editor+assembler.
    I made a small assebler for PF, but have had no time to debug it fully. Nor have I heard much interest of it here...
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-07-14 12:37
    Don't be mislead by the memory use on other systems!
    Me and two others implemented a JVM running javelin code.
    The javelin runs its jvm and virtual periheral code + native functions
    in 4K 12bit words on a SX48·(3K for the jvm, 1K for VP and native functions).
    Implementing the jvm in spin took 12K, and setting aside 16K to hold
    the java program binary image, only left 4K of main ram.
    Even worse was the implementation for the VP code: only 2 virtual
    peripherals could be implemented in 1 cog. The javelin requires 6 VP (3 cogs).
    I think the fact that flags are included in every assembly word
    leads to large memory waste. Many assembly instructions do not
    to test on flags, nor do they need to set flags, so these bits
    in an instruction are wasted. I believe if the cogs were 2K addressable
    with simple bytes they could execute much larger programs
    (1984·instructions versus 496 now).
    regards peter
    edited 2008-07-14 13:17
    Peter,
    This is the perennial argument between RISC and CISC instruction sets. RISC machines have to have relatively long words with all the fields present in every instruction. They're quite wasteful of memory bandwidth for instruction fetching. They're also very fast at instruction decoding and the instruction fetch and decoding hardware is very simple. CISC machines have relatively short words with fields present when needed. Instructions are variable length or of different formats depending on function. Use of memory for instructions is much more efficient. Instruction fetch and decoding hardware is much more complex and can be much slower (or much more complex or both).
    I can't speak for Chip, but I suspect that the use of a pretty pure RISC architecture was the only way to fit 8 processors on a reasonably small die.
    Post Edited (Mike Green) : 7/14/2008 3:16:42 PM GMT
    edited 2008-07-14 15:11
    Peter, let me get this straight. You have a program written in Spin, which is interpreted, which is a java virtual machine, itself an interpreter, which runs Java. Isn't this mind bendingly slow ? Sounds like a great feat anyway. I know nothing of the Java byte codes but I had a hard enough time getting an 8080 CPU emulator (VM) running with any speed writing it in Prop assembler.
    Frustrating thing is that for the lack of another 40K of RAM I could have the Prop host an 8080 C compiler (From CP/M). Waiting for Prop II.....
    edited 2008-07-14 17:12
    Very·slow. About 4-6 times slower than·the javelin itself. We are trying to convert
    the core code of the jvm from spin to pasm, but that too appears to require 4 cogs
    or so which does not make it easier. Perhaps for propII.
    regards peter
    edited 2008-07-14 18:03
    Peter, No idea about the performance of Javelin but if Spin is 10 times slower than prop asm (Say, I have no idea) and if the JVM is adds another factor of 10 (or whatever) then it starts to sound glacial.
    If code space for the JVM is the problem, I assume by your desire to spread it over many cogs, why not make use of the Large Memory Model (LMM) idea instead. Which is what I finally resorted to for less used parts of the 8080 emulator. It was either that or emulate some instructions by code in another COG which seemed messy to me and wasteful COGs.
    What would be cool is if you could use a LMM virtual machine compatible with that of ImageCrafts C compiler (Or the same if they don't mind) then we could integrate C and Java code or have Java with native C methods.
    Meanwhile someone else might want to compile Spin to the same LMM virtual machine and ....
    edited 2008-07-14 21:43
    The cog ram will still be 496 longs, so the JVM won't fit into a single cog. But design improvements should reduce the overhead of overlays.
    Paul Baker
  • jazzedjazzed Posts: 11,803
    edited 2008-07-15 00:19
    For the current Propeller:
    It's sad but funny at the same time watching the Propeller spin JVM spit out characters to the console [noparse]:)[/noparse]
    The spin version could be a little faster if all the current calls were embedded in a case statement, but it would be pretty hard to follow. Spin method calls are pretty expensive @ ~3.3us with no parameters to ~5us with one.
    LMM may be possible since it would eliminate the need to reproduce certain accessor functions in each cog running the JVM. There is a certain amount of IDE overhead required, and that would have to run in a second LMM. Code produced by the C LMM at (~3x size of spin) would be too big. Still one could try an "asm" LMM.
    I've tried implementing the IDE stuff in one cog, but it's too big. Also, one might be able to squeeze 3 VPs into one cog with a little rework. The margin would be tight and everything has to be done in 6.86us - 2 VPs fit comfortably now.
    For the PropII (if it's ever released):
    A C LMM variant would surely fit into PropII and number of VPs would double for one cog assuming a 2x speedup. The LMM interpreter would also be faster since more instructions can fit between rdlongs. With more cogs, there should be no issue in putting all the JVM into PASM.
    Seems JVM is mostly off topic in this thread though.
    Post Edited (jazzed) : 7/15/2008 2:50:07 AM GMT
  • hippyhippy Posts: 1,981
    edited 2008-07-15 13:50
    Oldbitcollector said...
    I'm curious if some of the expert level programmers here feel as if an on-board compiler might be possible for the propeller?
    Certainly possible but quite a lot of effort I would expect. Chip has it planned for the Prop II ( but, at last reports, likely not to be in the initial release ).
    JoannaK said...
    The early micro's usually had tokenisers and languages which could be easily 'compiled' but were quite simplistic and restrictive in nature. How long before Basics got away from just 26 variables, A-Z ? A lot of checking was also done at run-time rather than compile time, if a subroutine wasn't there it would stop when trying to find it. Those languages didn't have what people expect and demand these days. Spin isn't overly complicated but it's not simplistic either.
    Mike's idea of splitting a compiler into parts or passes is a very good idea and probably the only sensible option. There are implementation issues and resource constraints so the design gets more complicated than a PC-based compiler where one can casually ask for as much Ram as one needs and usually get it. Symbol tables probably have to be compact rather than just ASCIIZ strings, and even each pass may need its own overlays. All easy enough to handle but it starts to add up to more effort. Chip obviously believes the Prop II will have enough resources to do it.
    Matthew Hay said...
    My crazy idea is to write a modified spin interpreter and instead of reading from HUB ram reads directly from the SD card, which would allow a rather large file to be interpreted but of course this would be rather slow.
    It should be possible to do. I'm afraid I forget who it is working on turning Chip's ROM interpreter into LMM code but once that's done it should be fairly easy to change reads of Hub into calls which get the next byte/word/long from SD Card. Even executing LMM direct from boot Eeprom has its advantages, maximising Ram for data storage. Once the SD/Eeprom executing interpreter is loaded and running, almost the entire 32KB ( 256KB on Prop II ) is available for data use.
    As Ale notes, add caching and it hopefully won't be that slow. Extra Cogs can be used for caching and pipe-lining. The LMM code being executed doesn't have to be 32-bit PASM it can something else. As Peter comments, 32-bit PASM while fast isn't compact. The downside of something more compact is an extra overhead in expansion and execution time. A Thumb-style LMM could deliver reasonable compactness with minimal expansion over-head.
    Which then brings us to the tools needed to implement a compiler, get it working and debugged. That's most likely going to require quite a good degree of experience and knowledge in a number of areas, some of it quite specialised.
    Do we have enough access to the source to create such a tool?
    There's enough information available to create a self-hosted compiler. It's really a question of finding the people who can understand that information and have the skills and interest and will power needed to implement such a thing.
    Two factors which are likely to limit the number of people who might step forward is their lack of belief that the effort is worthwhile and the fact that as Chip is planning to do this anyway it could ultimately be wasted effort.
    Post Edited (hippy) : 7/15/2008 2:00:35 PM GMT
    edited 2008-07-15 14:15
    One question to ask is, do we need an on-board compiler ? Maybe that was just a generic question, and basically covers any on-chip, self-hosted development system ?
    If so then things like FemtoBasic, Forth and so on may fit the bill. The main problem I've run into in this area is that the code for the compiler, tokeniser or interpreter takes up so much Hub space that there's too little left for useful end-user programs. To regain space means removing functionality which in turn reduces the attractiveness. Adding BIOS, multi hardware support, hardware pinout portability and all manner of useful things improves usability but reduces the ability to use that usability.
    With interpreters which can load and/or execute code direct from SD or Eeprom that may not be so much of a problem. I think most of these problems will go away when the Prop II finally materialises. Although the tools will naturally expand to add more functionality there should still be plenty of free resources for end-user use.
    An onboard compiler does not have much utility to me. An onboard linker does however.
