how many LED's can a BOE power at once?
I have some super bright LED's 8000mcd and Im using them with the resistors they shipped with, which are either yellow brown brown or yellow violet violet. Its really tough to tell. Anyway I am wondering what math formula would I use to figure out how many LED's the boe can power at once. does it matter if I use a 9v battery or 4aa?
Actually I think Im going to add the whiskers to my tank and let it roam, just need to figure out where.
http://www.the12volt.com/ohm/page2.asp
Did you buy these leds on ebay if you did most of the time at lest the one that bought they are set up to run on ether 9 volts or 12 volts
··Thanks for any·
Sam
There are no Undo buttons in life.
This is for the BS2. Later models of Stamps use a different microprocessor (the SX) and have different rules for I/O current.
