quick basic stamp question
Hey when you burn out a I/o pin on the Board of education accidently due to over voltage or short circuit, does it damage the pins on the board or does it only damage the BS2 module?
Chris.
Chris.
I smoked pin 1 on a BS2 quite some time ago. It upset me. I got over it and now use the BS2 to test those "risky" setups (that do not require pin 1). As far as I can tell, everything continues to work fine. One day, I will probably make it a permanent part of something.
--Bill
You are what you write.
I soldered a 9V battery clip onto my BS2P Demo Board. Just so I could show a few guests one function I designed. I only used it once but left it there for convenience. Then one day the clip got stuck under the board and shorted a few pins of the Stamp. It blew out two of the I/O pins. I replaced the Stamp Chip and all is well again. Well worth the effort. If you want me to replace the chip for you let me know.
Dave...
D. A. Wreski
How kind of you! Thank you! (I also envy your skills with a hot iron.)
I'll just use it, as is. I have plenty of Stamps laying around just waiting for me to let the magic smoke out or put them to use . . . hopefully the latter, but I am REAL good at the former!
--Bill
