bs 2 operating temperature range?
i have a bs2 rev. G
and somewhere i had the spec's on its operating temperature range
but i can't find it
anyone know what the lowest temperature it will operate in?
and the highest temperature it will operate in?
or safe allowable range?
thanks
bob g
but i can't find it
thanks
bob g
www.parallax.com/tabid/295/Default.aspx
and click on the photos of the individual Stamps to see that the main line BS2, BS2sx and BS2e are now rated for the industrial range (-40 to +85 degC).
You have a BS2 rev G and that predates the improved specs., which arrived with BS2 rev J. See the following pages for the old specs, which were commercial (0 to +70 degC).
www.parallax.com/Portals/0/Downloads/docs/prod/stamps/stampscomparison.pdf
www.parallax.com/tabid/385/Default.aspx
That said, original BS2s I tested, even the commercial version, had no trouble operating in my CO2 environmental chamber at -55 degC up to +100 degC (I never took it higher than that). So the actual operating range may well be satisfactorily beyond the guaranteed range. I can't, of course, guarantee that! The old version of the BS2e did have problems at subzero temperatures with the brownout detector, but that has been resolved in the latest revision (BS2e rev E).
Tracy Allen
www.emesystems.com
thank you very much, my plan might see temperatures just below freezing, but i am going to try and safeguard against
that happening, the upper limit is far above what i have any use for so at least that end is well within spec's
its good to know that the bs2 can tolerate being under freezing, even if it would be an unusual event.
thank you very much
bob g
