Unknown input
I am trying to learn how to monitor an input pin on a Basic Stamp II. I have it on a test breadboard with a 6v power supply.
I have written several test programs like make an led blink and everything seems to work as expected.
However I wrote this simplt program and had nothing hooked to pin 8 and got the following results:
As you can see the input pin appears to report random values as to if it is high or low with nothing hooked to it at all.
Is this normal?
<<<<< Program code >>>>>
<<<<<< Results >>>>>>>
0,0,1,0,1,0,0,1,1,1,0
NosePicker
Is this normal?
input 8
checkpin:
if IN8 = 0 then ison
debug "0,"
pause 1000
goto checkpin
ison:
debug "1,"
pause 1000
goto checkpin
NosePicker
If you put a 10,000 ohm resister from IN 8 to ground, this will give you 0,0,0,0,0,0,0,0.· If you hook the resister to +Voltage, you will get 1,1,1,1,1,1,1.
Daryl
This situation Mike explained is called "floating". When you have a circuit hooked up, and you are looking for a high signal, you want the pin to always read a low in a neutral state. That's why you would put a 10K ohm resistor from the pin to ground, like Daryl stated. Then the basic stamp will see a "0" all the time, until a high signal is applied to that pin. Then the resistor link is basically ignored by the basic stamp, and it will read the high signal.
Good luck with the projects.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
NosePicker
