switch duration code
epicjr77
How would I write code if I wanted to read a switch that is normally closed only if it was open for longer than .25 seconds? Thanks
Assuming that closed gives a low level and open is high level...
Method 1, if the program can pause to see if the switch stays open for > 1/4 second.
Method 2, if counting the 1/4 second has to be merged into other tasks.
There are a lot of ways to do this, but you have to provide more detail about the goal.
Tracy Allen
www.emesystems.com
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 14
PingServo PIN 0
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
switch VAR IN15
Ticks VAR Byte
DO
DEBUG ? IN15
FOR sweepcount = 350 TO 1150 STEP 200
FOR x = 0 TO 1
PULSOUT 0, sweepcount
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
FOR sweepcount = 950 TO 550 STEP 200
FOR x = 0 TO 1
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
IF switch=0 THEN ' 'change 1 and 0 for real run
ticks=ticks + 1 MAX 25 ' or MAX 26 if it needs single shot action
ELSE
ticks=0 ' reset timer
ENDIF
IF ticks=1 THEN ' still open after 1/4 second
GOSUB Back_Up
GOSUB Turn_Left
GOSUB Turn_left
ENDIF
PAUSE 8 ' 8 milliseconds per loop available for more program tasks. Main loop runs in around 10 milliseconds.
LOOP
Sub
GetSonar:
LOW Ping
PULSOUT Ping, 5
PULSIN Ping, 1, rawDist
IF (rawDist < 2200) THEN ' adjust to change distance
IF (sweepcount < 750) THEN
GOSUB Back_Up
GOSUB Turn_Left
ELSEIF (sweepcount > 750) THEN
GOSUB Back_Up
GOSUB Turn_Right
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
IF (IN10 = 1) THEN ' Left Bumper Contact
GOSUB Back_Up ' Back up & turn right
GOSUB Turn_Right
GOSUB Turn_Right
ELSEIF (IN9 = 1) THEN ' Right Bumper Contact
GOSUB Turn_left
GOSUB Turn_Left
ENDIF
FOR pulsecount = 0 TO 5
PULSOUT LeftServo, 850
PULSOUT RightServo, 650
PAUSE 20
NEXT
RETURN
Turn_Left:
FOR pulseCount = 0 TO 20
PULSOUT LeftServo, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT RightServo, 850
PAUSE 20
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 40
PAUSE 20
NEXT
FOR pulseCount = 0 TO 7
PAUSE 20
NEXT
RETURN
IF ticks=25 THEN ...
instead of
IF ticks=1 THEN ...
That is because ticks counts up and is only at 1 for one cyclee, and the time limit happens when ticks=25 and stays there so long as the switch remains closed (switch=0). Also, your loop probably takes a lot longer than 10 milliseconds to execute, so it may be necessary to play with that limit.
limit CON 25 ' <---- play with this number to get the best time out limit
ticks=ticks + 1 MAX limit
'and later...
IF ticks=limit THEN ...
Tracy Allen
www.emesystems.com
