Question about the FullDuplexSerial Driver
Hello I would like to know if it is possible to increase the size of the circular buffers used to store inbound and outbound bytes from 16 that is their current value to something larger 1K or more?
thanks!
thanks!
Yes it is possible. But in FullDuplexSerial you have to change the SPIN-code and the PASM-code.
In the original file the buffersize is the hardcoded number "16" and some 16 - 1 = 15
If you go over 511-bytes you have to change some more of the PASM-code
(some calculations with the buffersizes must be changed from using a constant expression to a RAM-adress)
There is another serial object in the obex where it is easier to change
SerialMirror
obex.parallax.com/objects/189/
there it is enough to change some SPIN-constants
and the size of the DAT-section
Read the documentaion inside the file CAREFULLY
especially
4) This object is NOT suitable for driving multiple serial ports.
If you want multiple serial ports each with single object access, then
use FullDuplexSerial.
If you want serial comms through the same port from multiple objects,
then use THIS object.
If you want multiple serial ports each with multi-object usage, then copy
and rename this files for the number of unique serial ports.
best regards
Stefan
thx!
