maybe stupid question
Is there a quick and dirty way of how to send a signal between 2 propeller chips? If so how? I imagine there is some routine in there that is used for saving bit strings on a external eeprom or something like that.
I imagine you could send it via multiple pins on/off or by synchronizing them by using the same external crystal. But before I get started on this, I thought I ask.
Any help is appreciated.
You can use something like SPI or asynchronous serial for moderate speeds.· There's a thread somewhere here on a very high speed Propeller to Propeller link.
Probably the simplest would be to use an asynchronous serial link.· That requires only one line in each direction and there are a variety of routines available in the Propeller Object Exchange to do the byte by byte transfers.
As Mike said, it depends on your·project requirements.
The link below I wrote specifically for Prop-to-Prop·communication where you could "dump" large blocks of data back and forth in a very short amount of time.· It may or may not work for your needs.
http://forums.parallax.com/showthread.php?p=691952
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 7/9/2008 6:35:27 AM GMT
Super fast morse code; dots and dashes for zeroes and ones.
Send -.-.-.-. first so you can measure the average arbitrary speed at the receiving end.
Let the receiving end time out at the end of the data transfer.
