ping code
Hi I am trying to run sonar and 2 bumper switches on my robot at the same time, how ever it seems like the switches only work at a certain point in the program. Alos I am confused how to adjust the range of the ping
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 14
PingServo PIN 0
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
DO
FOR sweepcount = 350 TO 1150 STEP 200
FOR x = 0 TO 1
PULSOUT 0, sweepcount
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
FOR sweepcount = 950 TO 550 STEP 200
FOR x = 0 TO 1
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
IF (IN10 = 1) THEN ' whisker contacts
GOSUB Back_Up ' Back up & turn right
GOSUB Turn_Right
GOSUB Turn_Right
ELSEIF (IN9 = 1) THEN ' whisker contacts
GOSUB Turn_left
GOSUB Turn_Left
ENDIF
LOOP
Sub
GetSonar:
LOW Ping
PULSOUT Ping, 5
PULSIN Ping, 1, rawDist
IF (rawDist < 600) THEN
IF (sweepcount < 750) THEN
GOSUB Back_Up
GOSUB Turn_Left
ELSEIF (sweepcount > 750) THEN
GOSUB Back_Up
GOSUB Turn_Right
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
FOR pulsecount = 0 TO 5
PULSOUT LeftServo, 850
PULSOUT RightServo, 650
PAUSE 20
NEXT
RETURN
Turn_Left:
FOR pulseCount = 0 TO 20
PULSOUT LeftServo, 650
PAUSE 20
NEXT
RETURN
Turn_Right:
PULSOUT RightServo, 850
PAUSE 20
NEXT
RETURN
Back_Up:
FOR pulseCount = 0 TO 40
PAUSE 20
NEXT
FOR pulseCount = 0 TO 7
PAUSE 20
NEXT
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
Ping PIN 14
PingServo PIN 0
LeftServo PIN 13
RightServo PIN 12
rawDist VAR Word
sweepcount VAR Word
x VAR Byte
pulseCount VAR Byte
DO
FOR x = 0 TO 1
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
FOR x = 0 TO 1
PAUSE 20
NEXT
GOSUB GetSonar
NEXT
GOSUB Turn_Right
GOSUB Turn_Right
GOSUB Turn_left
GOSUB Turn_Left
ENDIF
LOOP
Sub
GetSonar:
LOW Ping
PULSOUT Ping, 5
GOSUB Back_Up
GOSUB Turn_Left
GOSUB Back_Up
GOSUB Turn_Right
ENDIF
ELSE
GOSUB Forward_Pulse
ENDIF
RETURN
Forward_Pulse:
PAUSE 20
NEXT
RETURN
Turn_Left:
PAUSE 20
NEXT
RETURN
Turn_Right:
PAUSE 20
NEXT
RETURN
Back_Up:
PAUSE 20
NEXT
PAUSE 20
NEXT
RETURN
- Stephen
Post Edited (epicjr77) : 7/9/2008 1:54:14 AM GMT
