Propeller-driven laser scanner
I just wrote a blog entry introducing my latest Propeller hobby project. It might be interesting to some of the folks here..
It's a laser scanner (think Pink Floyd at the planetarium) built using only a Propeller, two hard disk voice coils, and a few common ICs:
scanwidget.livejournal.com/29342.html
The blog post has high-level information about the project, and some pictures of the mechanical parts and the control board. The heart of the projector is a digital PID control loop for each axis. The output is PWM for an H-bridge chip, the feedback input comes from a light-to-frequency chip. The Propeller has a handful of fairly interesting/useful chunks of code:
Source code is in a Subversion respository, released under the MIT license. I haven't gone too far out of my way to make the objects fully general, since my first priority is performance, but there may be some reusable code:
svn.navi.cx/misc/trunk/laserprop/
- The Bluetooth interface uses a fairly generic shared-memory-over-serial protocol designed for high latency full-duplex links.
- The PID control loop and motor PWM is implemented by one cog per axis. This mostly involves doing multiplies about as fast as the Prop can, and timing output pulses using CTRA
- Vector graphics are interpolated on the Prop by a simple virtual machine, with first-order and second-order accumulators, and a jump instruction.
This is something I had considered when I got the prop, especially as I have a 50W CO2 laser.
Thanks for sharing. Have you considered making some galvos as others have done?
Cheers,
Graham
I've certainly considered building my own galvos. I could certainly get better torque to weight ratios [noparse];)[/noparse]
Still, part of me loves the idea of using only readily available 'hacked' mechanical parts. If PCBs were readily available, this would be a project that anyone with basic mechanical skills could put together in a weekend.
Cheers,
Graham
