SERIAL CONTROL OF BS2p24/PSC with BS2p40
Question? Can anyone tell me if it is possible to use· serial communication to control a Parallax Servo Controller/ BS2p24 combination with a BS2p40 in a Master/Slave setup? If it is possible,do you write commands to the BS2p24 or the
PSC? Also how would the command be written?
Thank You
Ken
Thank You
Ken
Check out the PSC "Serial" version documentation on the command strings needed to control it.
serout/serin and have the BS2p24· CASE/SELECT a command to the PSC.I've already wrote and tested the code now I need the BS2p40(MASTER) to control the BS2p24(SLAVE) CASE/SELECT.
Ken
