Blinking LEDs - Subloops?
Hi Forum - I'm doing my first project with a BS2 on a BOE board with PBasis2.5.
I'm controlling several LEDs (basically easy), but then I need to make a selected one blink at a fast rate (like 5/sec), while other LEDs stay lit. I'd like to somehow generate a 5/sec clock signal ("Blink") that continues outside (independent of) the main loop. Then I can just set RedLED (a PIN variable) = Blink to make it flash. So, in essence, I need to have TWO loops running; one to control the blink rate, plus the main loop.
If I just define a bit variable called "Blink" like this,
' Generate Blink squarewave 200ms (5/second)
BlinkCtr = BlinkCtr + 1
SELECT BlinkCtr 'BlinkClk counts to 200, then resets
CASE 100 'Assuming main loop time ~1ms
Blink = 1
CASE 200
Blink = 0
BlinkCtr = 0
ENDSELECT
then this Blink timing is screwed up if the main loop goes off and does something else for a few seconds.
Any ideas on how to make Blink remain a fixed squarewave (or some other approach to making the LED blink fast)?
Thx,
Jack
Blink = 1
CASE 200
Blink = 0
BlinkCtr = 0
ENDSELECT
Thx,
Jack
This may help you understand what you want to do ·····
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Wamv2_2.pdf
What’s a Microcontroller?· Chapter #2: Lights On – Lights Off · Page 37
This is where it start read all of Chapter 2
JackMac
You can ONLY do one thing at a time with a BASIC STAMP
Now you can·run thing one at time and make it look like you are doing two thing at one time but you are not
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 7/7/2008 7:08:54 PM GMT
When I jump out of my main loop with a gosub to set the LED states, I set some LEDs high or low and others to my variable "Blink" before returning to the main loop. But even though Blink is a 200ms squarewave, the LED is told to go to the value of Blink at the instant it's sampled, not the alternating value over time.
Seems like I may have to assign the blinking LED state value within a subloop inside the main loop, thus increasing the duration of the main loop (which I don't want to do).
Suggestions?
Thx,
Jack
Jack
