Protoboard Switch Current Rating?
DavidGreg
I'd like to use the protoboard's servo headers to power some rather hefty servos. Can someone from parallax comment on the current rating of the switch on the protoboard? Or alternately, give a part no. and I'll go look it up. This might be a good addition to the protoboard sheet?
-David
-David
The Protoboard's servo power circuitry includes a series inductor that's a surface mount 1uH device. I believe its rating is under 1A which would be well below any switch rating.
You're correct that it would be useful to mention this rating on the Protoboard schematic or documentation.
Paul Baker
What I was hoping to do was use the jumper to connect Vservo directly to VinSW. Vin would be connected to a battery, not to a wall wart. The inductor looks like it is only in line with the Vservo supply, so as long as my battery can supply enough current, I shouldn't have a problem with brownouts on the 5V and 3.3V rails.
Which brings me back to my original question - can the switch (and the board etc.) handle 10 amps? Or should I plan on running power separately to the servos.
-David
A few questions -
Is it ok to power the board and the servos with the same battery?
If so, would you recommend some sort of daughter card which had the servo headers and battery connector?
Conceptually, I'm having a hard time understanding "how far away" the high current lines need to be.
I don't necessarily mind not having the servo power switched so I think I'll avoid the relay.
2) A daughter card is a good idea. If you're doing your own PCB, you can make the traces wide enough for the currents involved. I don't remember the recommended widths. They depend on the copper thickness. Your PCB supplier should have recommendations.
3) I don't know "how far away". I'd be happy with 1/4 inch or so, further apart if they run together for a couple of inches.
