Timer Project, LED Display
It's been years (about 8) since I used my Basic Stamp.· My last project was a digital speedometer for my ATV.· I have the smaller BS1 from about 2000.
I'd like to make a new project.· I'm sure someone else has completed the majority of the leg work.· I tried to search the forums for the items I need, but I didn't find much.· Here is a breakdown of what I think I need.· Any additional advice is appreciated.
I want a timer (like a kitchen timer) that will count down from a variable number of minutes.· I want to output the time to a set of 4 large LEDs (they are 7-Segment common anode).· When the timer reaches zero, I want it to sound a piezo siren for about 10-20 seconds.· After that time the program can end.
Here is my basic plan:
1)···· How to set the amount of time?· I figure a DIP switch should make it easy to change the time on the fly.· 8 segments will give me up to 128 minutes.
2)···· I need the count down package.· I can add a clock (like a 555 timer) if necessary, but I don’t need it to be super accurate.· If the Stamp can keep it within 5-10 seconds over 10 minutes then I will skip the external clock.
3)···· I think I will need a controller chip to drive the LED display.· I’m going to start with just 4 LEDs (I might add 1/10 and 1/100th of a second later).· I used a serial LED display in the last project.· Can the Stamp drive the LEDs without a controller?
4)···· The siren should be easy to setup.· Can I drive the siren through the Stamp, or should I have the stamp trip a relay?
My hope is to find these 4 components and then just get them to work together.
Thanks.
Thanks.
Another idea is to use a Parallax SX-28 as the LED driver.·Download this SXB online manual and look at the example on page 242 towards the bottom. It is an SXB Example of a clock/timer which is what you want·with the exception of the alarm. If you already have some BS1 experience, it may be time to jump on the SX-28 bandwagon as learning SX/B (Basic)·is not that much·harder than PBASIC for the Basic Stamps.
http://forums.parallax.com/attachment.php?attachmentid=47155
Finally as another alternative you can check with BEAN (Terry Hitt) about these displays·he once sold and may be out of. I bought·4-5 as he originally sold them for $5 each over a year or more back. It was a·4 digit display·(with on board driver) that easily interfaced with a Basic Stamp 2 or SX chip. It was called the HC4LED and do a search on the forum for examples.
http://forums.parallax.com/showthread.php?p=640378
http://forums.parallax.com/showthread.php?p=630830
or others.
Here is his website (but did not see the HC4LED) - but he may have a couple of them available still.
http://www.hittconsulting.com/
Good Luck.
- Rick
I already have 6· 1.8" LEDs.· I want something you can see from across the room.· The HC4s are only .39" tall.
I beleive the SX-28 example is for common cathode LED displays too - but it could be modified in the code with probably not too much difficulty.
In the mean time I think I'll try to get the rest of the project running with my LCD Display (the serial one from my Speedo).
I'm also re-thinking the DIP switch to set the time. I wonder if a push button to add time might be easier. I'll only need whole minutes to start the clock.
