interconnecting basic stamp II and Arduino Diecimila is it possible??
Hello:
Im working on a project at my university related with robots. And what I need to do is to try to connect the arduino Diecimila, and the basic stamp II, so they can recive and send information to each other. For example, connecting a distance·sensor in the Arduino, and the servo-motors in the basic stamp 2 , so in a determined distance the robot has to·take another·direction.
But I don't know how to connect them and make a program using the data provided by the arduino.
any help....
any help....
You'll also need to implement some simple "handshaking" protocol, since the BS2 can ONLY recieve data when it's sitting in a "SERIN" statement. So you'll need some "master/slave" signalling approach -- which can be VERY simple.
One very simple approach is an "ACK/NAK" approach. Send a "sync" byte, then your message. If the BS2 doesn't get the "Sync" byte, it sends a "!" character to say "no good", or a "." character to indicate it DID get it.
