Voltagelevels that are SURELY detected as High / Low
StefanL38
hello,
Ok - as the answers to my last question are not fully satisfying me a new question:
What are the voltage-levels that are 100% SURE detected as logic HIGH or logic LOW
I guess with a powersupply of 3,3V
3,3V / 2 = 1,85V will be detected unsecure sometimes as low sometimes as high
So what is the range of a 100% surely logic LOW 0V - 1V ?
what is the range of a 100% surely logic HIGH 2,3V - 3,3V ?
I would appreciate if somebody could answer with NUMBERS like in the two lines above.
best regards
Stefan
best regards
Stefan
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
saying Vdd is 3,3V and not 3,0V or 2,9V.
Anayway, so i'm gonna ask another question:
did anybody ever have a prop-application in a noisy environment with classical switches ?
If yes how did you connect the switches in YOUR application ?
This is NOT longer a question about "tell me a 150% supersaveway how to connect switches to an IO-Pin that works in every superspecial case"
It's simply a question "how have YOU - REALIZED the connection in ONE of your applications ?
best regards
Stefan
Leon
that's NOT an answer to my question !
I'm NOT planning an application in a supernoisy environment.
I was asking: could somebody describe the switch-connection to the prop in ONE realized application
COMPLETELY regardless of an eventually specialized situation.
Just describe it.
And if you can only answer with a detailed specification:
a noiselevel averaged about 1 Million houses for a living-purpose like you find it on a livingroom-table
with a modern TV, somebody talking on a mobilephone 1m away
Or if you only want to make suggestion only for very specific numbers
Prop a LC-Display connected and some LEDs and that's all
specify a noiselevel about electromagnetic noise, noisy supplylines or whatever you like
and post a circuitry
best regards
Stefan
Paul Baker
Post Edited (Paul Baker (Parallax)) : 7/3/2008 5:48:53 PM GMT
The CE requirements specify the EMC requirements that all equipment sold in the EU is required to meet. Here is a list of the relevant standards:
http://www.rnelectronics.com/resources/latest-standards.html
A simple pull-up resistor of 10k with short PCB tracks will work OK. I've never had any problems with it.
Leon
Post Edited (Leon) : 7/3/2008 6:15:57 PM GMT
Vlow max=0.3Vdd=1V
Vhigh min=0.6Vdd=2V
There was a case a while ago where someone was feeding in a fairly low frequency sine wave and having problems measuring the frequency of it using the counters because it was too long in the in-between region. So you do need to be a little careful.
You can actually make a nice switch debouncer out of a flip-flop but thats probably more than what you need.
