Using a Stamp as an EPROM emulator
All,
I'm new to the forum.· I've got minimal experience with a BS1 and a Counterfit Stamp from several years ago.
I have a project idea and I'd like to know if it's feasable to do with a Stamp.
Basically, I'd like to build a 27C64/27C128 EPROM emulator using Stamps.
I have some old '286 laptops that have their BIOS stored in 2, 27C128 EPROMS.· These EPROMS are in an odd/even byte configuration.
Rather than edit, download, burn, and test BIOS changes, I'd like to use 2 Stamps as an In-Circuit Emulator (ICE).
Are there any obvious "gotchas" that I may have over looked.· The clock speed on the laptop is only 16 MHz, so I don't think timing will be much of an issue.
Should I use the BS1, BS2, or Prop for it?· Will the cost outweigh the advantage of making changes more or less "on-the-fly"?
Thanks in advance,
-Shawn
Thanks in advance,
-Shawn
Nope, you're in an "EPROM" write, burn, try, erase, write, burn, try again cycle. I THINK MAXIM has some static RAM parts with on-chip battery backup that might speed up the process. But no, a BS2 is WAY too slow. Yes, the cost would outweight the advantage.
Thanks for the Maxim tip.· I'll have to check them out.· Thanks to you, Mike, as well.
-Shawn
