Memory Stick Datalogger
Couple of questions
The memory stick features "5V supply with 3.3V/5V Safe I/O" pins.· Does this means that I do not need to use 1K resistor to interface with the Propeller even though it is powered by 5V?
Which mode is better to use (UART or SPI) with the Propeller?· Is there an advantage/disadvantage of one mode over the other?
WWW.HAPB.NET
"Don't ask yourself what the world needs - ask yourself what makes you come alive, and then go do it." - H.T.Whitman
WWW.HAPB.NET
The internal I/O reference voltage is set to the 3.3V supply on board making the I/O outputs suitable for 3.3V systems. So yes, you can connect directly, however be aware that a programming mistake can still cause damage to an I/O pin. As for mode that’s really a matter of choice, however I find that the serial mode is more useful on the BASIC Stamp because of the ability to format the output strings going to the device. On the Propeller this could easily be done either way. I hope this helps. Take care.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
I noticed the 2 LEDs on the PCB (Red, Green) but I did not see anything mentioned about them in the VDAPFirmwareSpec or MemoryStickDataloggerV1.0 pdfs. I would assume they are for visual indications of what is happening during read/write processes. If so, is there a reference available?
WWW.HAPB.NET
http://forums.parallax.com/showthread.php?p=733935
I wrote a small test·program that writes to my USB flash drive using USBDrive object.· It seems straight forward but the filename gets written at the end of each write statement.· Not sure why.· Perhaps someone can help.
The output file looks like this after 3 runs
My altitude is 535 feethapb.txt
It seems that it is writting everything I put under the DAT section of my code instead of just the information I am pointing to.· I added additional DAT statements and they appeared in the file so I must not be terminating the write statement properly.
Figured it out.· Need to terminate my DAT statements with Zero.· Never mind!!!!
WWW.HAPB.NET
Post Edited (Earl Foster) : 7/25/2008 4:44:30 PM GMT
I'm having trouble getting off of the ground. I'm setup for UART mode, I believe correctly (8 is NC though), and I used your exact code (thanks, btw) just to get something to write. Anyway, I can't get anything to write, would appreciate any help
2 things that bug me:
My lights never stop flashing, which I guess means that my monitor never connects?
Is your propeller Pin 13 RXD connected to pin 4 or 5 of the Datalogger? (is the MCU referred to on the DataLogger or is it the propeller)
