multiple variables in one UDP with pink
Hello all,
Does anyone out there know of a way to send multiple variable in a single UDP message using a pink module? I am using two sets of basic stamp and pink modules to send variables one direction between them. I am able to send and receive·a single variable using...
send:
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBI:192.168.1.82", CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:", l_values,CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0SB"]
receive:
SEROUT TX, Baud, [noparse][[/noparse]"!NB0RBM"]·········· ' Send Command To Read UDP Data
SERIN· RX, Baud, 100, timeout, [noparse][[/noparse]l_values]
I thought the logical way to do this is...
send:
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:", l_values,r_values,u_values,d_values,CLS]
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WSB"]
receive:
SERIN· RX, Baud, 10, timeout, [noparse][[/noparse]l_values,r_values,u_values,d_values]
But with this I get communication timeout! on the receiving end. I am using BS2s so the baud is set at 2400 on the pinks. I have attempted to send each of the _values individually in a single program but the receiving end only recognizes the first one (l_values). I am curious, perhaps there is some way to bundle the variables into a single "packet" that can be opened on the receiving end?·Any ideas would be greatly appreciated.
cheers!
send:
receive:
send:
receive:
cheers!
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Thanks for the reply. I made a few adjustments since my last post. I attempted to define an array of variables. Here some examples of what I am trying to do.
send:
' {$PORT COM13}
' {$STAMP BS2}
' {$PBASIC 2.5}
RX PIN 14
TX PIN 15
Baud CON 396
counter VAR NIB
nbvar VAR BYTE(16)
l_values VAR BYTE
r_values VAR BYTE
IR_freq VAR WORD
OUTPUT 3
OUTPUT 1
Main:
FOR counter = 0 TO 4
LOOKUP counter,[noparse][[/noparse]37500,38250,39500,40500,41500], IR_freq
FREQOUT 1,1, IR_freq
r_values.LOWBIT(counter) = ~IN0
FREQOUT 3,1, IR_freq
l_values.LOWBIT(counter) = ~IN2
nbvar(0) = l_values
nbvar(1) = r_values
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:",nbvar,CLS]
PAUSE 1
DEBUG HOME, DEC3 ? nbvar(0)
DEBUG DEC3 ? nbvar(1)
NEXT
GOTO main
receive:
' {$PORT COM14}
' {$STAMP BS2}
' {$PBASIC 2.5}
RX PIN 14
TX PIN 15
Baud CON 396
nbvar VAR BYTE(16)
l_values VAR BYTE
r_values VAR BYTE
main:
SERIN RX, Baud, 100, timeout, [noparse][[/noparse]STR nbvar\16\CLS]
PAUSE 1
GOTO main
Timeout:
DEBUG "Communication Timeout!"
END
When running these at the same time on their respective stamps I get what I would expect in the debug window for the send: stamp. But on the receiving end I get only readings for nbvar(0). nbvar(1) registers 000. Apparently I do not understand how arrays work or I am missing something important. After checking out section on arrays in the stamp manual I remain confused. Could you explain what you mean by appending variables back to back?
thank you,
if it happens that your byte variable r_values is zero, that will act not as data but as the string terminator.
You could get around that by setting the high bit of all the variables. It looks like your program is just using the 5 lowest bits. Or, send the data as ascii HEX:
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:",HEX2 l_values,HEX2 r_values,HEX2 u_values,HEX2 d_values,CLS]
and on the receive side,
SEROUT TX, Baud, [noparse][[/noparse]"!NB0RBM"] ' Send Command To Read UDP Data
SERIN RX, Baud, 10, timeout, [noparse][[/noparse]HEX2 l_values,HEX2 r_values,HEX2 u_values,HEX2 d_values]
With regard to arrays, this statement,
does not send the entire array (if that is what you were expecting). It only sends the first element of the array. If you want to send all 16 bytes, this is the syntax
SEROUT TX, Baud, [noparse][[/noparse]"!NB0WBM:",STR nbvar\16,CLS]
That and the similar string array command receive will work too with PINK, but keep in mind here too that ascii zero in the string is the same as CLS.
Tracy Allen
www.emesystems.com
That did the trick... I added 1 to each of the variables and used an array. The readings come out good on the receiving end.
cheers!
