Terminal program to use with Dongle-Basic
For quite some time I·have happily used·Femtobasic 2.004·modified for Propterminal as posted by Oldbitcollector·here ·http://forums.parallax.com/showthread.php?p=649540.·For a new project I·switched to·an up-to-date DongleBasic 3.007·using the·Parallax terminal program at the moment.·Two questions:
- I·miss Propterminal, anyone modified·a DongleBasic for Propterminal? My own attempts did not work out, I basically·replaced·the BB_FullDuplexSerial object with the PC_Terminal object,·replaced all "ser.rx"·and "ser.tx" statements by "trm.getkey" and·"trm.out". It kind of works, I see text on the Propterminal screen and can type statements, but the first character of each input line is·not echoed, the "shift" key on input does not function, "CR" echoes as "K" at the end of the line, and the position of text on the screen is all wrong. Any idea·what I am missing?
- I need to create some·non-scrolling data screens.·The PC_Terminal object specifies the following·codes for positioning text on the screen, are these true for all terminal programs?
··· · $00 = clear screen
''···· $01 = home
''···· $05 = Grafik (mode,x,y follows)
''···· $08 = backspace
''···· $09 = tab (8 spaces per)
''···· $0A = set X position (X follows)
''···· $0B = set Y position (Y follows)
''···· $0C = set color (color follows)
''···· $0D = return
Nico Hattink
''···· $01 = home
''···· $0D = return
Nico Hattink
Most terminals will support basic backspace/carriage return/linefeed/bell etc.
Unless you go to something like ANSI, or some other terminal type derivative,
you won't have control of things like X,Y and color.
Someone here wrote an ANSI emulation for the Prop, (I think) but it's been a while back.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
Nico
